My monitor randomly black screens
TheProPizza
My monitor randomly black screens for about 5 seconds every 5-10 min and i cant figure out why, i have a gigabyte m28u (4k 144hz), an old dell monitor (1080p 60hz), a 4060 ti 16gb. Ive updated all the drivers and updated everything, and tried disabling gsync and freesync. Any one have any ideas what wrong?
Usually a sign of a bad cable. Does it happen to both monitors or just one?
"Black Out"
1tb Samsung 970 Evo | 2x 2tb Crucial MX500 SSD | Fractal Design Meshify S2 | Corsair HX1200 PSU
Dedicated Streaming Rig
 Ryzen 7 3700x | Asus B450-F Strix | 16gb Gskill Flare X 3200mhz | Corsair RM550x PSU | Asus Strix GTX1070 | 250gb 860 Evo m.2
just one but ive tried a different cable and plugging it into different ports and the same happens
The cables that come with monitors are usually cheap bottom of the barrel garbage. Did you try with a quality cable or ones that came with the monitors?
"Black Out"
they were both from monitor boxes but they both worked fine on my friends pc, he also has a 4k 144hz monitor
does hdmi 2.1 support 4k 144hz 12bit fine cause i cant find a clear answer
