Need some fans and RGB help
Go to solution Solved by kitnoman,
1 hour ago, DarkStar2117 said:
But when it comes to the rgb I am very confused. Should I just get splitters or get an RGB control?
If anyone would like to give some tips on what I should do or should I just stick with the case fans and get a simply exhaust fan to make things easier. Either way, I would still like some help on the rgb.
Honestly for a $600 or around $1000(if you include the already bought components and even if it's $1500, performance should be the priority. But since it's a pc and it's really your choice, form and aesthetics can be your priority. But just putting it out there. For this build, you really don't need the full $120 win11 bought from microsoft as there are other legit market where you can get an authentic windows 11 key for $13-20. I would also advice you to get a z690 or z790 motherboards as, overclocking with undervolting the cpu is one of the best part of 13600k.
If you really want RGB, I would suggest to just get a case that comes with a fan and rgb hub already.
PCPartPicker Part List
CPU: Intel Core i5-13600K 3.5 GHz 14-Core Processor  (Purchased For $0.00)
CPU Cooler: Deepcool AG400 BK ARGB 75.89 CFM CPU Cooler  (Purchased For $0.00)
Motherboard: ASRock Z690 Pro RS ATX LGA1700 Motherboard  ($119.99 @ Newegg)
Memory: Silicon Power GAMING 32 GB (2 x 16 GB) DDR4-3200 CL16 Memory  ($49.97 @ Amazon)
Storage: TEAMGROUP MP33 1 TB M.2-2280 PCIe 3.0 X4 NVME Solid State Drive  (Purchased For $0.00)
Video Card: XFX Speedster SWFT 309 Radeon RX 6700 XT 12 GB Video Card  ($318.36 @ Newegg Sellers)
Case: Phanteks Eclipse P400A Digital ATX Mid Tower Case  ($69.99 @ Newegg)
Power Supply: Thermaltake Smart 600 W 80+ Certified ATX Power Supply  (Purchased For $0.00)
Operating System: Microsoft Windows 11 Pro OEM - DVD 64-bit  ($20.00)
Case Fan: Phanteks PH-F120SK 50 CFM 120 mm Fans 3-Pack  ($35.99 @ Amazon)
Total: $614.30
Generated by PCPartPicker 2023-12-03 09:10 EST-0500
Budget: 600$ USD
Country: US
Games, programs or workloads that it will be used for: Programming for school and some games (Baldurs Gate, Persona, city skylines, and oxygen not included)
https://pcpartpicker.com/list/zxzYmD
Here's the link to what I have so far. My brother got me a intel Core i5-13600k for the holidays, and so I thought I'd get a better case and some more fans but i think having 7 RGB fans is a bit much for a first build. I plan on getting these fan splitters...
https://a.co/d/dwvWo83
49 minutes ago, DarkStar2117 said:
Budget: 600$ USD
Country: US
You'd be better with a fan+RGB hub rather than a half dozen splitters 😛
https://www.amazon.com/Addressable-Lighting-Magnetic-backplane-Addressble/dp/B08JQFKXYK/ref=sr_1_3?crid=3QOT0CO7Q7RPB&keywords=rgb%2Bfan%2Bhub&qid=1701611927&sprefix=rgb%2Bfan%2Bhu%2Caps%2C213&sr=8-3&th=1
System : AMD R9 5900X / Gigabyte X570 AORUS PRO/ 2x16GB Corsair Vengeance 3600CL18 ASUS TUF Gaming AMD Radeon RX 7900 XTX OC Edition GPU/ Phanteks P600S case /  Eisbaer 280mm AIO (with 2xArctic P14 fans) / 2TB Crucial T500  NVme + 2TB WD SN850 NVme + 4TB Toshiba X300 HDD drives/ Corsair RM850x PSU/  Alienware AW3420DW 34" 120Hz 3440x1440p monitor / Logitech G915TKL keyboard (wireless) / Logitech G PRO X Superlight mouse / Audeze Maxwell headphones
Total: $614.30
