How to convert external SSD and use it like a USB flash drive?
yargd
I'm trying to make a bootable Windows 10 install USB with an external SSD. I  put it in an enclosure but the system can't see it as a USB, just a storage drive. Please help.
I'm trying to make the system see the external SSD like a USB flash drive. I need this to do other stuffs like recovery USB, etc. Thanks.
8 minutes ago, HoffmannMS said:
This tutorial helped me some time ago. Hope you have good results too :
Thanks for answering, but this is not exactly what I'm looking for.
19 hours ago, Electronics Wizardy said:
Try using rufus. It has a option to allow external hdds/ssds to be used as the install medium.
No luck. is this even possible?
Yea Ive done this with rufus multiple times in the past.
Somethng like ventroy should also work here.
You're the man. Thank you.
