Greetings,
It's been a while since I built a computer, I decided to change my current case for the new Lian Li Lancool 216 X Black Mid Tower:
https://lian-li.com/product/lancool-216/
I am really excited, now I'm wondering what's the best configuration since I have never put the radiator on top.
I'm planning this:
And there is the possibility to put two more fans at the buttom.
1-Is this the best configuration? or do you recommend other?
2-Is it useless to put 2 fans at the buttom, do they need to be exhaust or intakes?
i7 10700k @ 5.05 Ghz
MSI 1070TI titanium
Corsair H100i pro XT 240mm
MSI z490 tomahawk
16 Gb (2 x 8 GB) Patriot Viper Steel - 4000mhz - 16-16-16-34
Just have the rad as intake and leave the back open. So much positive pressure then that there is no use for a back fan.
Any reason for an aio? A thermalright peerless assasin 120 matches or beats most and costs a fraction.
As for fans in the bottom. Yes entirely useless.
Rad should go at the top, you can't easily put it at the front given those are 160mm fans. Regardless, this is a super basic setup that you shouldn't be sweating over.
Also +1 to ditching the AIO unless you know you want it entirely for looks.
Ryzen 7 7800x3D -  Asus RTX4090 TUF OC- Asrock X670E Taichi - 32GB DDR5-6000CL30 - SuperFlower 1000W - Fractal Torrent - Assassin IV - 42" LG C2
Ryzen 7 5800x - XFX RX6600 - Asus STRIX B550i - 32GB DDR4-3200CL14 - Corsair SF750 - Lian Li O11 Mini - EK 360 AIO - Asus PG348Q
Is because of looks and that I already have it
Exactly is for looks.
MSI 1070TI titanium
MSI z490 tomahawk
On 12/1/2023 at 12:22 PM, EspinalAndres said:
Greetings,
I'm planning this:
Here are the possibilities:
Since you didn't indicate your PC setup, it's hard to say what's best. Please share that info.
I've been using computers since around 1978, started learning programming in 1980 on Apple IIs, started learning about hardware in 1990, ran a BBS from 1990-95, built my first Windows PC around 2000, taught myself malware removal starting in 2005 (also learned on Bleeping Computer), learned web dev starting in 2017, and I think I can fill a thimble with all that knowledge. 😉 I'm not an expert, which is why I keep investigating the answers that others give to try and improve my knowledge, so feel free to double-check the advice I give.
My phone's auto-correct is named Otto Rong.🤪😂
It is on my signature
MSI z490 tomahawk
MSI 1070TI titanium
MSI 1070TI titanium
MSI z490 tomahawk
MSI z490 tomahawk
MSI 1070TI titanium
Nothing changes, unless you plan to pull out the great 160mm fans the case comes with in the front, the rad should go up top. Its designed for that.
Top bracket even comes off to make installation easier.
MSI z490 tomahawk
MSI 1070TI titanium
Thanks. I have signatures turned off. I second @GuiltySpark_'s suggestion.
