Isonzo running badly on a pc that should run it great
sylSYLsyl
HEYHEY so me and a friend we're playing isonzo (both at 1440p ultra and 7900xt) only difference is he has a 7700x and  i have a 5700x yet he has 70% more fps than me anyne know a possible cause?
Maybe the game is highly CPU-bound.
Corps aren't your friends. "Bottleneck calculators" are BS. Only suckers buy based on brand. It's your PC, do what makes you happy.  If your build meets your needs, you don't need anyone else to "rate" it for you. And talking about being part of a "master race" is cringe. Watch this space for further truths people need to hear.
Ryzen 7 5800X3D | ASRock X570 PG Velocita | PowerColor Red Devil RX 6900 XT | 4x8GB Crucial Ballistix 3600mt/s CL16
70% from 1 generation?
No way 70% boost by 1 gen.
Check CPU, GPU usage etc.
temps.
¯\_(ツ)_/¯ I have no idea, not familiar with the game. Have you monitored your CPU and GPU utilization while playing? Are you totally sure all your graphical settings are the same?
temps.
cpu usage is about 60% on all cores and gpu doesnt go above 70 for some reason no fps lock or v sync
