First pc build ever and first non laptop, need help - edited
Can someone tell me if this is a good build, imma update the bios for the motherboard - https://pcpartpicker.com/list/Ntmdrv
If someone has suggestions and tips I would like to hear some : )
The build is 790 euro local prices, and second hand cpu gpu and ram from a friend and i know its in good shape
PRICE OF PARTS
case - COUGAR Duoface Pro RGB Black / 180 BGN
motherboard - Gigabyte A520 AORUS Elite / 210 BGN
psu - Cooler Master - MWE 700 Bronze  / 150 BGN
MVMe - SSD памет Crucial - P3, 1TB, M.2, PCIe / 115 BGN
RAM - xpg dr80 x2 + cpu ryzen 5 5600x (from a friend) / 350 BGN
GPU - AMD Sapphire pulse 6700xt 12gb (2nd hand) / 500 BGN
TOTAL - 1,505 BGN / 837.18 USD / 770 EUR
Here are some sites that are in the country I live in, there are no better parts for my budget imo.
https://www.ozone.bg
https://desktop.bg
https://plasico.bg/komponenti
https://ardes.bg
Edited by Pun
6 minutes ago, Pun said:
Can someone tell me if this is a good build, imma update the bios for the motherboard -  https://pcpartpicker.com/list/4cB84M
Did you misclick?  700+ for a 6600XT?
What's your actual budget?  You can do better on almost every aspect.
Onyx AMD Ryzen 7 7800x3d / MSI 6900xt Gaming X Trio / Gigabyte B650 AORUS Pro AX / G. Skill Flare X5 6000CL36 32GB / Samsung 980 1TB x3 / Super Flower Leadex V Platinum Pro 850 / EK-AIO 360 Basic / Lian Li Lancool II Mesh C / AOC AGON 35" 3440x1440 100Hz / Mackie CR5BT / Corsair Virtuoso SE / Cherry MX Board 3.0 / Logitech G502
7800X3D - PBO -30 all cores, 4.90GHz all core, 5.05GHz single core, 18286 C23 multi, 1779 C23 single
Emma : i9 9900K @5.1Ghz - Gigabyte AORUS 1080Ti - Gigabyte AORUS Z370 Gaming 5 - G. Skill Ripjaws V 32GB 3200CL16 - 750 EVO 512GB + 2x 860 EVO 1TB (RAID0) - EVGA SuperNova 650 P2 - Thermaltake Water 3.0 Ultimate 360mm - Fractal Design Define R6 - TP-Link AC1900 PCIe Wifi
Raven: AMD Ryzen 5 5600x3d - ASRock B550M Pro4 - G. Skill Ripjaws V 16GB 3200Mhz - XFX Radeon RX6650XT - Samsung 980 1TB + Crucial MX500 1TB - TP-Link AC600 USB Wifi - Gigabyte GP-P450B PSU -  Cooler Master MasterBox Q300L -  Samsung 27" 1080p
Plex : AMD Ryzen 5 5600 - Gigabyte B550M AORUS Elite AX - G. Skill Ripjaws V 16GB 2400Mhz - MSI 1050Ti 4GB - Crucial P3 Plus 500GB + WD Red NAS 4TBx2 - TP-Link AC1200 PCIe Wifi - EVGA SuperNova 650 P2 - ASUS Prime AP201 - Spectre 24" 1080p
Steam Deck 512GB OLED
OnePlus:
Other Tech:
- Ubiquiti Amplifi HD mesh wifi
I wouldn't pay $300 for a 6600xt, let alone 700+ lmao
If you're willing to pay that much for a card, get a 4080 or 7800xt
AMD 3600x, 16GB DDR4 3200MHz CL14, GTX 1080, and Ungodly Amounts of Storage
Seems pretty good overall, but I would rather get a b550 chipset motherboard, a cheaper cpu like the 5600, and a bit better gpu, for a reasonable price ofc
Not a good build. In fact it is almost horrible, but lacks enough pricing to be sure. I suggest you follow the outline provided in the pinned topic at the top of this forum. It provides readers with sufficient information to give useful advice.
I fixed it thanks and yeah i think this is my budget the cpu and ram is from a friend so its a good price deal
Country of purchase?
Bulgaria - for price those were the cheapest i found and a friend helped me
I know Eastern Europe pricing is up the arse compared to Western Europe and especially US but even then this is pricy, 740eur for a PC so far of a 5600X and other parts isn't too impressive. Like new parts pricing for 3 year old stuff.
Can you link us maybe to some local stores so we can look ourselves?
Desktop: Ryzen 7 5800X3D - Kraken X62 Rev 2 - STRIX X470-I - 3600MHz 32GB Kingston Fury - 250GB 970 Evo boot - 2x 500GB 860 Evo - 1TB P3 - 4TB HDD - RX6800 - RMx 750 W 80+ Gold - Manta - Silent Wings Pro 4's enjoyer
SetupZowie XL2740 27.0" 240hz - Roccat Burt Pro Corsair K70 LUX browns - PC38X - Mackie CR5X's
Current build on PCPartPicker
You have parts that have no prices, some of which are fixed. How in the world do you expect reasonable suggestions with so many variables?
Don't use parametric selection for parts. Select the actual part. This will allow you to use part configuration to manually enter the price.
Without knowing how much the fixed items are, there is no way to make reasonable suggestions.
my budget is this tbh i cant spend more atm
here are some sites
https://desktop.bg
https://ardes.bg
idk how is this going to help but here you go i hope it does
'' Like new parts pricing for 3 year old stuff.''
maybe but the stuff that are new doesn't mean they are all better + they have a price big difference and its just out of my budget : (
Edited by Pun
Its fixed, thanks
