Lost tightening screws for nzxt x62
Go to solution Solved by StoryVFX,
10 minutes ago, mariushm said:
Thread should be standard UNC 6/32 (like the screws on the case panels) - just compare the threading to the threads of the screws you have on motherboard to screw it in place.
If the threading is the same, you can buy the bigger screws from amazon or some other places
search for unc 6-32 thumb screw or knurled or other keywords
ex 5.5 length : https://www.ebay.com/itm/174424938155
10 mm length : https://www.amazon.com/Colourful-Aluminum-Knurled-Tighten-Computer/dp/B0BYWY2R75/
Damn bruh that's gonna take a long ass time for shipping im in Europe, im just gonna buy a new aio what do you think of corsair h100x 240mm elite
