Question from a newbie about how to plugin case fans
Veinama
Hey, I got a Lian Li Lancool III case, the RGB version. Can I plugin the front 3 fans which as far as I'm concerned are daisy chained into a singular 4 pin PWM straight into the motherboard? I don't have any 3rd party RGB Hub, only whatever was included in the case. My worry is that the power draw would be too big or something (I'm completely clueless). If that would be wrong could you guys tell me how it should be done? Grateful for any responses.
In case it's needed my mb is B650 AORUS ELITE AX
yes you can
it won't you'll be fine
Message me on discord (bread8669) for more help
Current parts list
CPU: R5 5600 CPU Cooler: Stock
Mobo: Asrock B550M-ITX/ac
RAM: Vengeance LPX 2x8GB 3200mhz Cl16
SSD: P5 Plus 500GB Secondary SSD: Kingston A400 960GB
GPU: MSI RTX 3060 Gaming X
Fans: 1x Noctua NF-P12 Redux, 1x Arctic P12, 1x Corsair LL120
PSU: NZXT SP-650M SFX-L PSU from H1
Monitor: Samsung WQHD 34 inch and 43 inch TV
Mouse: Logitech G203
Keyboard: Rii membrane keyboard
Damn this space can fit a 4090 (just kidding)
