Starting new build... Opinions and help wanted :)
Exponetialy
What ya'll think of this? https://pcpartpicker.com/list/nzdwkJ
How do ya'll think it will preform? (will the parts work well together)
would like the build to stay under 2,300$ I'd also like it to keep nearly the same style.
-Exponetialy
-Exponetialy
A few less than stellar choices.  All of them need adjusting IMO.  I'll let you pick a better case.
CPU upgrade to best gaming CPU in the Universe.  Even better than the 5th best 7700X.
Cooler - 7800X3D is fine with the Assassin
Motherboard - cheaper and better.  NZXT should stick to cases/peripherals.
Memory - G. Skill for guaranteed stability, 6000CL30 for eeeking the tiny half-frame benefit for cheaper.  Unless you really want RGB?
Storage - just as good for gaming but cheaper
GPU - 7900XTX > 4070Ti by a good bit (at sub $900, I may grab one)
Case - all you
PSU - Good quality Gold rated new hotness from @filpo's best friends company
All in all a better performing machine for the money.
PCPartPicker Part List
CPU: AMD Ryzen 7 7800X3D 4.2 GHz 8-Core Processor  ($358.98 @ Amazon)
CPU Cooler: Thermalright Peerless Assassin 120 SE 66.17 CFM CPU Cooler  ($33.90 @ Amazon)
Motherboard: Gigabyte B650 AORUS ELITE AX ATX AM5 Motherboard  ($217.99 @ Amazon)
Memory: G.Skill Ripjaws S5 32 GB (2 x 16 GB) DDR5-6000 CL30 Memory  ($104.99 @ Newegg)
Storage: Lexar NM710 2 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  ($89.99 @ Amazon)
Video Card: Sapphire 21322-01-20G Radeon RX 7900 XTX 24 GB Video Card  ($895.00 @ Amazon)
Case: NZXT H510 Elite ATX Mid Tower Case  ($129.99 @ Amazon)
Power Supply: Thermaltake Toughpower GF A3 - TT Premium Edition 1050 W 80+ Gold Certified Fully Modular ATX Power Supply  ($120.99 @ Newegg)
Total: $1951.83
Generated by PCPartPicker 2023-11-30 14:34 EST-0500
Onyx AMD Ryzen 7 7800x3d / MSI 6900xt Gaming X Trio / Gigabyte B650 AORUS Pro AX / G. Skill Flare X5 6000CL36 32GB / Samsung 980 1TB x3 / Super Flower Leadex V Platinum Pro 850 / EK-AIO 360 Basic / Lian Li Lancool II Mesh C / AOC AGON 35" 3440x1440 100Hz / Mackie CR5BT / Corsair Virtuoso SE / Cherry MX Board 3.0 / Logitech G502
7800X3D - PBO -30 all cores, 4.90GHz all core, 5.05GHz single core, 18286 C23 multi, 1779 C23 single
Emma : i9 9900K @5.1Ghz - Gigabyte AORUS 1080Ti - Gigabyte AORUS Z370 Gaming 5 - G. Skill Ripjaws V 32GB 3200CL16 - 750 EVO 512GB + 2x 860 EVO 1TB (RAID0) - EVGA SuperNova 650 P2 - Thermaltake Water 3.0 Ultimate 360mm - Fractal Design Define R6 - TP-Link AC1900 PCIe Wifi
Raven: AMD Ryzen 5 5600x3d - ASRock B550M Pro4 - G. Skill Ripjaws V 16GB 3200Mhz - XFX Radeon RX6650XT - Samsung 980 1TB + Crucial MX500 1TB - TP-Link AC600 USB Wifi - Gigabyte GP-P450B PSU -  Cooler Master MasterBox Q300L -  Samsung 27" 1080p
Plex : AMD Ryzen 5 5600 - Gigabyte B550M AORUS Elite AX - G. Skill Ripjaws V 16GB 2400Mhz - MSI 1050Ti 4GB - Crucial P3 Plus 500GB + WD Red NAS 4TBx2 - TP-Link AC1200 PCIe Wifi - EVGA SuperNova 650 P2 - ASUS Prime AP201 - Spectre 24" 1080p
Steam Deck 512GB OLED
OnePlus:
Other Tech:
- Ubiquiti Amplifi HD mesh wifi
Case - all you
Total: $1951.83
Thanks! I'll check this out
CPU: *AMD Ryzen 7 7800X3D 4.2 GHz 8-Core Processor  ($358.95 @ B&H)
CPU Cooler: *Deepcool AG620 BK ARGB 67.88 CFM CPU Cooler  ($47.99 @ Newegg)
Motherboard: *MSI PRO B650-P WIFI ATX AM5 Motherboard  ($176.99 @ Amazon)
Memory: *G.Skill Flare X5 32 GB (2 x 16 GB) DDR5-6000 CL30 Memory  ($99.99 @ Newegg)
Storage: *Western Digital Black SN850X 2 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  ($114.99 @ Amazon)
Video Card: *MSI VENTUS 3X E OC GeForce RTX 4070 Ti 12 GB Video Card  ($799.99 @ B&H)
Case: *Lian Li LANCOOL 216 ATX Mid Tower Case  ($94.99 @ Newegg Sellers)
Power Supply: *MSI MPG A850G PCIE5 850 W 80+ Gold Certified Fully Modular ATX Power Supply  ($114.99 @ Amazon)
Total: $1808.88
Generated by PCPartPicker 2023-11-30 18:33 EST-0500
