Can I use a RX 7900XTX Water block on a 7800?
TobyAtmos
I have searched high an low to find a water block for 7800XT, all I can find is 7900XTX. are they cross compatible? I don't know enough to find what I'm looking for. Pls help.
I doubt you could. Even reference board designs are completely different.
Project Hot Box
Oppbevaring
Why is the 5800x so hot?
As said above definately not , Apart from anything else pitting a water block on a 7800XT puts you on the same price as a 7900XT or maybe even a 7900XTX which would have significantly better performance.
Thats generally why only top stack cards have by far the most Waterblock options.
CPU : Ryzen 7 7800X3D @ -18mv all core except -13mv on Core 5 because its a pig.
CPU Cooler : Deepcool AK620 Zero Dark
Mobo : MSI B650M-A Wifi MATX
Ram : 32GB (2X16GB) Corsair Vengeance DDR5 6000MHZ CL34
GPU : Reference Design RX7900XT sold by Saphire running at 1050MV undervolt and +15% PL (355w)
Storage : 1TB WD SN770 + 2TB Samsung 970 Evo
PSU : Corsair HX750w Platinum
Case : Asus Prime AP201 All Mesh MATX
Case Fans : Arctic p12's everywhere i can fit them in , 7 In total.
Monitor : LG 27GP850-B.BEK 1440p Nano IPS 180Hz
Keyboard : HyperX Alloy Core RGB
Mouse : Corsair M65 Elite RGB
Headset : Corsair HS35 Gaming Headset
