Need help finding a drilling template for Logitech G920 and shifter
I'm making a custom stand for my Logitech G920 and the Driving Force shifter so I don't have to buy one. I don't have a limit for materials, and I'm planning to build it out of wood. I have access to all sorts of tools and those aren't an issue either.
The problem that I'm having is that I can't find a drilling template for the G920 anywhere. I've searched for hours on multiple different devices (in case that was an issue) and I literally can't find anything. I need the template so I can start work on the stand, so if anyone has any sort of past experience with this sort of thing or if you have a template, please let me know!
 Thanks so much!
| Mark Solutions as Solutions | Just Because Nobody's Replied Doesn't Mean Nobody's Thinking | Refresh Often| Bottleneck Calculators are BS|
Main System: CPU: Intel Core i5-12600K/ COOLER: Be Quiet! Pure Rock Slim 2/ RAM: 32GB (2x 16GB) Corsair Vengeance LPX DDR4 3600MHz/ GPU: MSI RTX 3070 LHR Ventus 2x OC/ SSD1: 512GB NVMe M.2 SSD & SSD2: SK Hynix P41 2TB/ Case: Fractal Pop! Air (Black RGB TG Clear Tint)/ PSU: EVGA SuperNOVA 750 P2
Temps under load: CPU: Under Cinebench r23 looped for 30 minutes, temps reach around 60-67 C (140-152.6 F)
GPU: Under Fur Mark for 45 minutes, temps reach around 72-78 C (161.6-178.4 F)
Second System: CPU: Intel Core i7-4790/ COOLER: Thermalright Peerless Assassin 120SE/ RAM: 16GB (2x 8GB) Team Group DDR3 1600MHz/ GPU: AMD Radeon PRO W5700 GPU/ SSD: 250GB Samsung SATA SSD & HDD1: 1.5TB 2.5" HDD & HDD2: 500GB 2.5" HDD/ Case: Fractal Define 7 No Window/ PSU: Corsair RM1000X
Temps under load: CPU: Under Cinebench r23 looped for 30 minutes, temps reach around 50-56 C (122-136.8 F)
GPU: Under Fur Mark for 45 minutes, temps reach around 69-73 C (156.2-163.4 F)
Laptop: Lenovo IdeaPad Gaming 15IMH05 (Intel Core i5-10300H, 16GB DDR4 2933MHz, Nvidia GeForce GTX 1650 Ti, 500GB NVMe M.2 SSD & 500GB SATA SSD)
Temps under load: CPU: Under Cinebench r20 looped for 30 minutes, temps reach around 87-92 C (188.6-197.6 F)
GPU: Under Fur Mark for 45 minutes, temps reach around 81-84 C (177.8-183.2 F)
Phone: iPhone SE 2 (2020 version)
 Thanks so much!
By template you mean the space between the holes for hardmounting the G920?
I am not sure you even need a template, just screw in screws and use a sharpie to mark their heads and place it on top of a piece of paper or a used packaging material.
Yes.  I'm going to hard mount it. I just need to know the space. Thanks!
