ASUS PRIME X470-PRO M.2 bandwith? For Samsung 980 Pro with Ryzen 9 5900x
I wasn't quite able to figure out the relation between the pcies and generations and ssd speeds, im sorry. In the manual it says something completely indecypherable for me - ive included a screenshot.
If I put it into the top m2 slot, given that im using ASUS PRIME X470-PRO, Ryzen 9 5900x and Samsung 980 Pro 2TB - is the SSD losing any speed? If so, how much? If I was to eventually buy a new mobo, what spec am i looking for? Thank you!
Yes, it'll lose speed.  It's a Gen 3 slot, so the Gen 4 drive will run at Gen 3.
Will you notice?  Depends on your use case.  Gaming?  No.  Productivity?  Possibly.
Onyx AMD Ryzen 7 7800x3d / MSI 6900xt Gaming X Trio / Gigabyte B650 AORUS Pro AX / G. Skill Flare X5 6000CL36 32GB / Samsung 980 1TB x3 / Super Flower Leadex V Platinum Pro 850 / EK-AIO 360 Basic / Lian Li Lancool II Mesh C / AOC AGON 35" 3440x1440 100Hz / Mackie CR5BT / Corsair Virtuoso SE / Cherry MX Board 3.0 / Logitech G502
7800X3D - PBO -30 all cores, 4.90GHz all core, 5.05GHz single core, 18286 C23 multi, 1779 C23 single
Emma : i9 9900K @5.1Ghz - Gigabyte AORUS 1080Ti - Gigabyte AORUS Z370 Gaming 5 - G. Skill Ripjaws V 32GB 3200CL16 - 750 EVO 512GB + 2x 860 EVO 1TB (RAID0) - EVGA SuperNova 650 P2 - Thermaltake Water 3.0 Ultimate 360mm - Fractal Design Define R6 - TP-Link AC1900 PCIe Wifi
Raven: AMD Ryzen 5 5600x3d - ASRock B550M Pro4 - G. Skill Ripjaws V 16GB 3200Mhz - XFX Radeon RX6650XT - Samsung 980 1TB + Crucial MX500 1TB - TP-Link AC600 USB Wifi - Gigabyte GP-P450B PSU -  Cooler Master MasterBox Q300L -  Samsung 27" 1080p
Plex : AMD Ryzen 5 5600 - Gigabyte B550M AORUS Elite AX - G. Skill Ripjaws V 16GB 2400Mhz - MSI 1050Ti 4GB - Crucial P3 Plus 500GB + WD Red NAS 4TBx2 - TP-Link AC1200 PCIe Wifi - EVGA SuperNova 650 P2 - ASUS Prime AP201 - Spectre 24" 1080p
Steam Deck 512GB OLED
OnePlus:
Other Tech:
- Ubiquiti Amplifi HD mesh wifi
Am i understanding that means it will run at speed of 3.938 GB/s? gen 3 x4.
And the 980pro is 7gb read and 5gb write, meaning im losing a lot, but admitedly a lot of speed that i wouldnt use, given its for gaming.
And the other slot is gen 3 x2, meaning 1.969 GB/s, so i could put my old Samsung 980, which is 3.5gb/3gb, and use it for storage anyways, correct? would it be okay to game too?
