Computer only starts (and posts) once after CMOS reset
Drummyralf
Go to solution Solved by Drummyralf,
Welp, I reinstalled windows and downgraded my BIOS. Seemed to fix the problem for now.
Setup:
Ryzen 5 1600
Asrock Radeon 6700 XT
HyperX Fury 2400 mhz DDR4 (2x 8GB) (edit: in slot A2 and B2)
Asus Rog Strix B350F motherboard
Samsung NVMe M.2 ssd 980 1 TB (windows drive)
Samsung Evo 860  250 GB
WD Blue 1 TB
Windows 10 64 bit
(edit)Seasonic M12 II Bronze 620 Evo edition
I switched GPU about a month ago. The rest of the build has been working for years.
Updated BIOS to 6203 a month ago.
PC worked great for about a month.
Short description:
I can only post (and launch Windows) after I reset CMOS and do a "discard and exit" in my BIOS. If I Save and Exit, the PC does not post.
After a CMOS reset, I can also boot by overriding boot by the drive that has Windows on it.
If I power off windows, it doesn't post. Need to reset CMOS again.
If I don't reset CMOS, my motherboard gives a white LED indicator (indicating GPU fault) but it also does this with my old GPU installed.
Things I tried:
-Using only 1 stick of ram (tried both)
-Replacing CMOS battery with a quality new one (says 3.2v on multimeter, old one says that as well)
-Switching GPU to different PCIE slot
-Switching back to old GPU
The last thing I did last night was installing Steelseries GG suite for my new Rival 3 Mouse. This morning, it didn't post.
I uninstalled GG driver (by CMOS reset, discard and exit) but that didn't fix the issue.
Also, currently only have a generic keyboard conneted for all the testing, no other USB devices.
Any help would be greatly appreciated. Thank you!
Whoops, forgot about that!
