Will my 4070 work properly with a 650w powersupply?
TTboyx
Go to solution Solved by Hinjima,
16 minutes ago, TTboyx said:
I'm replacing my old gpu and upgrading to a rtx 4070 (ASUS Dual GeForce RTX 4070 OC Edition)聽
My current gpu is an EVGA 650w g2 gold i bought in 2016
Will there be any problems at all?
Yes. it will be fine 馃檪 No problem!聽 The 4070 draws a max of 200w.聽 I run my 340w RTX 4080 on a 750w without any issues.
Linus actually ran the RTX 4090 on a 650w and it didn't crash.
Your EVGA 650w g2 gold is definitely getting a bit on the older side but its been running fine until now so it should last a while longer.
Congratulations on getting the 4070! What a nice gaming card.
I'm sure you could boot into Windows and even play some games without any problem. If you are not going to be away from the computer while leaving it on running intensive tasks it's probably alright. I've blown out older power supplies leaving them on for 3D rendering.
CPU: AMD Ryzen 9 3950X聽 聽Motherboard: MSI X570 Gaming Edge Wifi聽 聽Case: Deepcool Maxtrexx 70聽 聽GPU: RTX 3090聽 聽RAM: Corsair Vengeance LPX 3x16GB 3200 MHz 聽 PSU: Super Flower 850W
4070 runs off a single 8 pin and has pretty modest power requirements, so I wouldn't expect you to have any problems.
My CPU is an i7 8700 btw (if that makes any difference) lol
That CPU draws around 130w during 100% load ( full usage ) . So if the GPU and CPU run at 100% you are drawing 330w, the rest of the system uses maybe 50w ( Ram uses around 6w per 8GB, fans around 3w ) .
650w is more than enough 馃檪聽 Plenty of headroom, no problemo!
Happy gaming
馃憤馃憤
Hey I can one up that by 15w!!
CPU : Ryzen 7 7800X3D @ -18mv all core except -13mv on Core 5 because its a pig.
CPU Cooler : Deepcool AK620 Zero Dark
Mobo : MSI B650M-A Wifi MATX
Ram : 32GB (2X16GB) Corsair Vengeance DDR5 6000MHZ CL34
GPU : Reference Design RX7900XT sold by Saphire running at 1050MV undervolt and +15% PL (355w)
Storage : 1TB WD SN770 + 2TB Samsung 970 Evo
PSU : Corsair HX750w Platinum
Case : Asus Prime AP201 All Mesh MATX
Case Fans : Arctic p12's everywhere i can fit them in , 7 In total.
Monitor : LG 27GP850-B.BEK 1440p Nano IPS 180Hz
Keyboard :聽HyperX Alloy Core RGB
Mouse : Corsair M65 Elite RGB
Headset : Corsair HS35 Gaming Headset
  • 3 weeks later...
Is the EVGA 650w still viable? i bought it back in 2016 and been using it ever since
I have a brand new RTX 4070聽 i want to install in my PC聽
What yall think??
