Does the Dell S2721DGFA and G2724D have the same bezel and panel dimensions?
levi_athan1701
Go to solution Solved by BuzzingBee,
I looked at outline dimensions for both monitors. Both have the same pixel length and width, while G2724D has slightly slimmer bezel size.
Hi there,
Just a quick question here. As the title says, does anyone know if the aforementioned Dell monitors have the same panel and bezel dimensions?
I currently own a S2721DGFA and want to get two G2724D monitors in a triple landscape setup. I'm really hoping that they will align perfectly.
Any assistance is greatly appreciated!
"That is from an obscure language known as French- Mr. Data, the french language for centuries on Earth represented civilisation- But surely sir... - I suggest you drop it Mr. Data" - ST TNG
PC spec: CPU: RYZEN 9 5950X | GPU: SAPPHIRE NITRO+ AMD RADEON 6800XT | MB: MSI MAG TOMAHAWK x570 RAM: G.SKILL TRIDENT Z NEO 32GB (2x16GB) DDR4-3600 (OC to 3800 14-15-15-25) COOLING: NOCTUA NH-D15, BE QUIET! SILENT WINGS 120 & 140mm| CASE: IN-WIN 707 | 5.25" BAY: LG WH16NS60 INTERNAL BLU-RAY OPTICAL DRIVE | PSU: SEASONIC PRIME PLATINUM 1000WUPS: POWERSHIELD COMMANDER TOWER 1100VA
PERIPHERALS: KEYBOARD: CORSAIR K95 PLATINUM XT BROWN SWITCH | MOUSE: ASUS ROG GLADIUS III | CONTROLLER: PDP AFTERGLOW WIRED CONTROLLER, DUALSENSE
DISPLAYS: LG 34GN8502x DELL S2721DGF | LG C1 48"
HT & audio stuff:  AVR: MARANTZ SR7013 | STEREO AMPLIFIER: YAMAHA AS-501 | SPEAKERS: DALI OBERON 7 & DALI ZENSOR 1 & 2x SVS-SB2000 | HEADPHONE DAC+AMP: TOPPING L30+E30 | HEADPHONE: SENNHEISER HD6XX, BOSE QUIETCOMFORT 35 II | MICROPHONE: AUDIO-TECHNICA AT9934USB | BLU-RAY PLAYER: PANASONIC UB820
