my newer seasonic powersupply dies while my almost 5 years old Delta PSU runs the same PC just fine
Morris_lee_9116
Go to solution Solved by OddOod,
What else is in the system. Where are you located? Is your power maybe dirty? Do you have a UPS? What mobo do you have?
It's possible you've lost the electronic lottery twice, but in my experience, when I have a double RMA, it's been the mobo.
i have a Seasonic Focus-GX850 came back from RMA like for the 2nd time, so i installed it back into my PC, and after installing it for a few days it broke again, the PSU don't turn on anymore, making me have to waste my time changing it back to my old Delta power supply again
i sent it to RMA and the people there said it could probably be motherboard's problem(it doesn't make sense since old delta PSU runs it just fine with no issue whatsoever
does anyone have any clue what happened?
Refresh the page before you quote or reply, i edit my message often
"Freedom is the right of all sentient beings"
Current PC Spec
CPU: AMD Ryzen 5 3600
CPU Cooler: Scythe Mugen 5
Motherboard: MSI B550 Tomahawk
RAM: XPG D10 White 2x8GB 3200 CL16
GPU: EVGA RTX 3060 Ti XC
Storages: 1x512GB Intel 760P M.2 NVME(boot drive)
1x2TB Umax M1500 Gen4 M.2 NVME(Game storage)
1x1TB Adata SU800 Ultiamte 2.5 inch Sata3 SSD(Game storage)
1x3TB Toshiba 7200RPM CMR drive
Case: Lian Li Lancool II Mesh
PSU: Seasonic Focus GX-850
Keyboard: Ducky Zero 3108 Cherry MX red
Mouse: Logitech G603 LightSpeed
Headphone: Audio-Technica ATH-M20x
Microphone: AVerMedia AM310
Flight stick: Thrustmaster T16000M FCS 3 pack
My Steam Profile (from SteamDB)
  • Value: $308
  • Games owned: 229
  • Games played: 163 (71%)
  • Hours on record: 4,976.9h
47 minutes ago, Morris_lee_9116 said:
 the people there said it could probably be motherboard's problem(it doesn't make sense since old delta PSU runs it just fine with no issue whatsoever)
I'm not so sure that truly rules out your motherboard - though I'm not sure you could definitively find out without additional replacement parts either
AMD 3600x, 16GB DDR4 3200MHz CL14, GTX 1080, and Ungodly Amounts of Storage
5950X/3080Ti primary rig  |  1920X/1070Ti Unraid for dockers  |  200TB TrueNAS w/ 1:1 backup
I live in Wanlong Taipei Taiwan, idk how clean my power is, i do not have a UPS, my motherboard is MSI B550 Tomahawk
so i guess is should RMA my motherboad? what other parts should I RMA at the same time
Current PC Spec
  • Value: $308
  • Games owned: 229
All good info. What is the symptom that causes you to RMA? just no power? semi power? did you try booting it by shorting 24pin green to ground?
Knowing nothing else I'd recommend getting a UPS. It's never gonna hurt the system
no power, fan didn't spin even with Eco mode off, i did try booting with the included attachment you use to test PSU(idk the name)
Current PC Spec
  • Value: $308
  • Games owned: 229
Wow. That's bonkers. I guess you have actually double lost the lottery. Sometimes the dice gods do not smile upon you. Upside is the SS has pretty good RMA history and at this point, if you're disappointed with them, they should be willing to cash you out on it.
I guess I'll RMA my motherboard once I'm done modding Wii for my friend, can't do it without a computer, and borrowing a Xbox to play forza until it came back, would a normal UPS substitute for dedicated surge protector or it's already built in?
Current PC Spec
  • Value: $308
  • Games owned: 229
  • 2 weeks later...
A UPS should have a surge protector built in. I like the Cyberpower 1500VA
