How to compare between 2 ISP providers ? Optical fiber
PSP.
Hello ,
I really found 2 good offers isp providers , both same speed 200 Mbps
but how to compare between  2 internet service providers ?
Speed test is nothing , I really feel stupid question
but asking myself ]really how to compare ?
I will try 1 month first each provider ,but which tests I have to try ?
I have no idea how to compare except speed test
Google Chrome.lnk
I do not know the key to success, but the key to failure is trying to please everyone
Hi buddy, it really comes down to the following:
1. Customer Service
2. Price
3. Speed
4. Any Caps or Download Limits
Here in the UK, the vast majority of the fibre / copper wires are owned and maintained by Openreach (BT), but in the interest of fairness, they sell / lease lines to various different ISP's (Sky, Vodafone, Plusnet......) There are a handful of other Network Operators such as Virgin and maybe some niche rural supply ISPs but it all comes down to the above.
Other regions might be different though.
Where are you based?
Bedroom PC - Thermaltake Tower 500 - Intel Core i5 13600k @ 5.4P / 4.4EGhz -  MSI Pro-A Wifi Z790 Mobo DDR5 - 32GB Ram - Gigabyte RTX 4090 - 1TB Samsung 990Pro NVMe - Corsair HX1200i PSU - Dual Loop CPU + GPU cooled with double EK Quantum Surface S240 Rads + double EK Quantum Surface S120 Rads + 2 x Corsair Hydro XD5 Pump / Res Combo.
Extension PC - Hyte Y60 - Intel Core i9 9900k @ 5Ghz -  MSI Meg Ace Z390 Mobo - 16GB Ram - Palit RTX 3080ti - 256GB Samsung NVMe - Corsair AX850 PSU - CPU + GPU cooled with EK Coolstream S120 + EK Quantum Surface S360 + EK Quantum Surface X240M - Corsair Hydro XD5 Pump / Res Combo.
Living Room PC - Lian Li o11 Dynamic - Intel Core i7 8086k @ 5.1Ghz -  Gbyte Z390 I Aorus Pro Wifi Mobo - 16GB Ram - EVGA RTX 2080ti - 256GB Samsung NVMe - EVGA B5 850W PSU - CPU + GPU cooled with dual EKWB 360 Rads + G1 side EKWB distro plate.
Annex PC - Thermaltake Tower 100 - Intel Core i7 8700K @ 5.1Ghz - Gbyte Z390 I Aorus Pro Wifi Mobo - 16GB Ram - EVGA GTX 1080ti - 256GB Samsung NVMe - ??PSU - CPU + GPU cooled with dual EK Quantum Surface P120M Rads + Barrow 3-in-1 Block, Res & Pump.
Spare PC - Corsair 250D - Intel Core i7 3770k - Asus P8Z77 I Delux Mobo - 16GB Ram - iGPU - 256GB Corsair SSD - BeQuiet P11 750 PSU - CPU + GPU cooled with EK Coolstream S240 + S120 Rads + EK Pump / Res Combo
Spare PC 2 - Corsair 280X - Intel Core i7 4790k - Asrock H97M ITX Mobo  - 16GB Ram - EVGA GTX 980 - Corsair SFXL600 PSU - CPU + GPU cooled with triple EK Coolstream S240s + EK Pump / Res Combo
Living Room AV Setup 5.1.4 - Yamaha RX-A2060 - 2 x B&W CM9s2 - 2 x Monitor Audio FX Silvers - 4 x B&W CCM665s - B&W CMCs2 - SVS SB13 Ultra - LG OLED65C6V.
Extension AV Setup - Sonos ARC + Sub (Gen 3) - LG OLED65C1. Yamaha RX-V1700 - 5 x Monitor Audio C265s (2 Zones).
Bedroom AV Setup - Yamaha WXC-50 - 2 x B&W CM1s - Rel Quake - LG OLED42C2.
1. Customer Service
2. Price
3. Speed
Middle East Kuwait
I was happy with 5G but not with my synology nas and plex
as I read
Most wireless internet providers use CGNAT so you can't remote stream by just forwarding the port.
I have switched back to fiber , all good but want speed up to 200mbps
both same price almost
1. Customer Service : checking
2. Price : so close
3. Speed : both 200
4. Any Caps or Download Limits : no limit
because reasons above , trying to know tests to decide , like Jitter etc...
but seems like have to focus Customer Service ,
1. Customer Service
2. Price
3. Speed
by the way , better to ask isp static ip instead of pppoe ?
2. Price : so close
3. Speed : both 200
If you have the ability to sign up for trial periods or not be tied into a contract then it might be worth trying a few ISPs to see what your 'real-world' download rates are and latency. Also, call their CS line at a peak time and see how long it takes you to get through to an agent.
You should only be asking for a static IP on your WAN port if you need it for things like Web servers / services that you / other people need to connect to.
TBH, I suspect that Static IPs like this won't be available on domestic tariffs as they tend to be reserved for business / commercial use which will come with a hefty premium.
When I jumped to my current ISP I had to pay 5$ a month for my static IP on top of doubling my monthly, but at least the new one stopped yelling at (and throttling) me for "too much upload while staying under the bandwidth limit"
5950X/3080Ti primary rig  |  1920X/1070Ti Unraid for dockers  |  200TB TrueNAS w/ 1:1 backup
Was that on a 5G or Fibre network?
I really have no issue with PPPOE but if Static IP performance better . I will try ,
also still feeling Free Trial they will give you best available but when you start pay first month
not good as free trial , I will try paid one month each ,
not sure but will contiue with pppoe
Fiber. But they should be similar things. They just run the whole region as a single corporate network
PPPoE is how you connect to your account at the ISP, it has nothing to do with if you are given a static public IP, dynamic public IP or CG-NAT.
A static IP is also not necessarily needed to have a public IP, though it may be the only way to opt-out of an ISPs CG-NAT.
So really it depends if you actually need a public IP address or not.  I believe gaming often works better if you do and if for any reason to need to access a local PC on your home network when away from home its useful, though Tailscale may also be an option for that.
For me personally not being on CG-NAT would be first priority, with speed/reliability in second place.  Of course CG-NAT is really the only thing you can ask the ISP about, everything else would be more down to reviews from other people on the same ISP.
Router:  Intel N100 (pfSense) WiFi6: Zyxel NWA210AX (1.7Gbit peak at 160Mhz) WiFi5: Ubiquiti NanoHD OpenWRT (~500Mbit at 80Mhz)
Switches: Netgear MS510TXUP, Netgear MS510TXPP, Netgear GS110EMX
ISPs: Zen Full Fibre 900 (~930Mbit down, 115Mbit up) + Three 5G (~800Mbit down, 115Mbit up)
so , useful for my part ?
using synology nas and tried to enable DDNS but not work
I think need ,
I think need ,
Static IP is useful in avoiding needing DDNS, though I'm not sure how it stands now but last I checked free DDNS services still requires you to login periodically to keep the service alive.  Personally I pay for my own domain and set it manually on there.
Eh. My friend used to run a Valheim and ARK server with a Dynamic IP. It worked just fine. Comcast the ISP we both use doesn't really change IP's to often. He would just give me his IP if it changed. Now if you need access to services on your home network then you can use a DDNS service and many are free. In my opinion a static iP for most people is overkill and not really worth an extra expense. Due to the fast we have exhausted all the IPv4 addresses your ISP might not offer such an option.
In some cases they can be enabled in a router, but if you have ISP supplied equipment that might not be supported. The last time I used such a service I recall needing an account and I think some of them have an app you can download that will update the IP information as it changes.
