Switching from 5700xt to 3070ti no display help
RicHorse
I recently got a 3070ti and I can't get it to display but it turns on with the RGB and fans, my old 5700xt works with no problems so I know the PCIE slot is fine.
Everytime I try switching to the Gigabyte 3070ti, my motherboard shows the solid red VGA light, and my monitors show No Signal.
Here are my current system specs:
Mobo: B450 tomahawk Max
CPU: Ryzen 5 3600
PSU: Corsair 850W RM850x
RAM: Corsair Vengeance 32GB DDR4 3600MHZ
SSD: Kingston NV2
OS: Windows 11
I've used DDU to uninstall the AMD drivers but still nothing works. I've also tried
Clearing CMOS
Setting PCIE settings to Gen 3 instead of auto as B450 doesn't support Gen 4
Reseating ram
Not sure what else to try, should I install the 3070 drivers then run DDU tool to get rid of the amd drivers? I'm running out of ideas and starting to think the card might be dead.
Is the 3070 ti new or used?
Corps aren't your friends. "Bottleneck calculators" are BS. Only suckers buy based on brand. It's your PC, do what makes you happy.  If your build meets your needs, you don't need anyone else to "rate" it for you. And talking about being part of a "master race" is cringe. Watch this space for further truths people need to hear.
Ryzen 7 5800X3D | ASRock X570 PG Velocita | PowerColor Red Devil RX 6900 XT | 4x8GB Crucial Ballistix 3600mt/s CL16
It's used
Just now, RicHorse said:
It's used
Is there any other system you can test it in?
Do you have recourse to return it?
I had my friend test it in his similar system and it failed as well. I got the card for free cause they were upgrading to a 4080, was just wondering if there's anything else i can do to try to make it work, cause it was working in the original build
Tried kissing it yet? It might woke up
JK
I think I have a similar situation like this, at the time all I did was reinstall the windows since I need to change the SSD anyway. And in my case it is not that it didn't have any display, it is that the GPU keeps crashing while gaming
