How do i use a mini pcie wifi card in a pc?
JoHeJo06
I tried 2 wifi cards in my pc, they both got picked up perfectly and drivers are installed. When i try to use wifi, it says that no networks are found.
does anyone know hoe i fix this?
Did you install the antennas?
Current Network Layout:
Current Build Log/PC:
Prior Build Log/PC:
Why do you need two WiFi cards?
Yes, I harvested them out of an old laptop.
I only need one, i just had 2 laying around so i tested both and thu both didn’t work
you put tiny wire antennas inside of a metal box?
They most likely did not as laptop antennas usually run up to the screen so are a lot of work to remove.
Motherboards with a WiFi M.2 socket need a kit that includes the antennas and cable to mount them to the outside case. eg
https://www.amazon.com/Antenna-RP-SMA-Extension-Computer-Bracket/dp/B08XNBN7TT/
or a PCIe adapter:
https://www.amazon.com/MZHOU-Converter-Dual-Band-Bluetooth-Including/dp/B0882Z3MKL/
Router:  Intel N100 (pfSense) WiFi: Zyxel NWA210AX (1.44Gbit peak at 160Mhz 2x2 MIMO, ~900Mbit at 80Mhz)
Switches: Netgear MS510TXUP, Netgear MS510TXPP, Netgear GS110EMX
ISPs: Zen Full Fibre 900 (~915Mbit down, 115Mbit up) + Three 5G (~900Mbit down, 115Mbit up)
Folding@home Recent WUs
Upgrading Laptop CNVIo WiFi cards to PCIe
or a PCIe adapter:
they came out of a laptop, we ripped it appart...
Then you definitely need them outside of the case.
