Is no exhaust fans good? + Configuring case fans
26 minutes ago, IndirectX said:Is it really okay to have a PC without any exhaust fans?
It will run hot, but it will be okay, just losing some performance if the heat is high enough and it will get worse overtime.
But, there's no reason you can't add another fans but yourself.
27 minutes ago, IndirectX said:Cooler Master MasterLiquid ML240L RGB V2
This AIO is bad for the price, I wouldn't recommend it.
AIO could be configured as the exhaust, yes, but you still need a main exhaust fans that is not on the AIO to achieve best airflow.
28 minutes ago, IndirectX said:And finally, can the component's RGB be configured (through software or hardware)? Is there any fan hub which comes with the case/cooler or should it be brough separately?
Most if not all recent generation motherboard has ARGB headers, so they could be controlled through a software from the motherboard.
But there is also RGB hubs, which not really necessary, but better for cable management and if there's some special connector for the RGB.
