Logitech G304 Left click issue
Solved by Poinkachu,
42 minutes ago, Mr.Turtle2820 said:Hello,
I purchased a Logitech 304 mouse 3 months ago, and while it initially worked well, I have noticed some issues with inconsistent clicking. Specifically, when I try to drag a file or item, I have to apply more significant pressure to the left button.
I have already tried to reinstall the Logitech software, but the issue persists.
Can you offer any assistance or advice on how to resolve this problem? Thank you.
Most likely worn out / broken switch
