Sas pcie card and cables?
I need a pcie adapter and cables to get this working with my motherboard. Can someone recommend a set?
I have 6 drives consisting of seagate exos, WD enterprise and dell branded constellation
Need more information. Do you have a backplane in the case, or do you have a hot swap caddy, or are you just dealing with internal drives?
If it's the latter, then you'll probably want just any IT mode SAS HBA that has "8i" in the name (ie 8 internal ports, or two physical ports).
If it's a 6G card (which is probably the most economical), then you'll need two SFF-8087 to SFF8482 cables - you can get them with molex or SATA power connectors, just pick the ones that you have the available power connectors for.
If it's a 12G card, you'll want SFF-8643 to SFF-8482 cables.
LSI 9207-8i and SFF-8087 to SFF-8482 breakout cable.
You sure those are SAS drives? I own SATA Seatagte Exos and WD Enterprise drives but perhaps they have SAS versions under the same name...
I'm no expert, but I have seen SAS to 4x SATA cables used with HBAs like this in the past, maybe that's what OP is intending to do.
Perhaps. 6 SATA ports is kind of in the upper range of what comes on most consumer motherboards. Maybe it's just a case of needs more ports but I guess we'll just have to wait for OP to clarify.
Doesn't really matter, SAS cards can handle SATA drives.
I'm aware. Point being if he doesn't actually need a HBA but thinks he does.
These are the types of questions you have to ask yourself when helping people on the forum. Don't face value let people waste money if it turns out they don't need to. He didn't say he needs more ports but that's why we're waiting for clarification.
It was going to be internal drives, such a ripoff to try and get anything with caddies.
I had some 6g and 12g drives though I just assumed they’re cross compatible bug I’m returning them all and reordered used 8tb sata drives. The used 8tb drives are double capacity, low hours and will run without special hardware.
For software I wanted to try Synology DSM using ARPL but quickly found out I’m not very good at using docker. I’m considering truenas or proxmox but think I’ll need truenas for for disk management anyway as I don’t intend on touching command line.
Initially I’m building a nas intended just for use as a nas but later on I intend on virtualising or just running my current N100 torrent ‘server’ which consists of win11, qbittorrent, serviio and private internet access.
I used to run a pi400 but minidlna struggled with permissions and Debian got corrupted after a power loss. The n100 though it seems to use more power than the pi’s 6W goes into a sleep state of 0.5w when not in use
