Cpu speed dropping for no reason at all
Hello i have a weird problem,my pc is working fine and suddenly cpu speed drops to 1ghz for no reason at all,cpu speed is not still,and i always have to restart pc to return to 3.6 ghz,i cleaned my pc changed thermal paste and everything and still same,my motherboard is asus a68hm-k,pls help,and cpu temperature is cold and idle i changed thermal paste,no thermal throttle at all,i have lc power 650watt psu 80+ bronze,8gb corsair vengeance ram 1600mhz,120gb ssd gigabyte
image.thumb.png.acbb36f626f14382c9693865065e4259.pngimage.thumb.png.d40899fc88cab7a43b57d853619687cf.png
IMG_20230918_213406.thumb.jpg.a031b2e94bc26e6b2ca89492021ffd61.jpgIMG_20230918_213400.thumb.jpg.9203c490028391f1a5137ed5501a7768.jpgIMG_20230918_213113.thumb.jpg.3c2381cdf0114b788a689eec417cd221.jpgIMG_20230918_213101.thumb.jpg.3f25e714337c11844d97212c4e11b788.jpgIMG_20230918_213327.thumb.jpg.b852726fbc88d4edc168f157e70fbf9a.jpgIMG_20230918_213343.thumb.jpg.5b01b9ac7387db8308f620cb5e220740.jpgHere are some bios setting i don't even know what they mean i never changed anything so help and explain what all this means in CPU settings,and help me turn that off to reduce cpu speed cuz temperatures are always cool,when i play games its on 80-90% under load sometimes 100 but not always
CPUs are supposed to clock down when under a lower load to save power; that's normal behavior.
Or are you saying that the CPU is running at 1.39GHz even if placed under load? - Like when playing a game or running a CPU benchmark
Well sometimes while playing cpu drops at that speed,but mostly when im just watching youtube cpu speed drops :/,it's irritating me
Since you have a dedicated graphics card, watching YouTube shouldn't put much strain on the CPU - the GPU will do the video decoding.
Does it cause any performance issues, or is it just something that you noticed happening?
Well i see stutters,fps drops etc...
That could just be a result of using an old Athlon X4, at least for more modern games.
Could you try running a stress test or benchmark like Cinebench or 7-Zip and see if the CPU runs at the speed it's supposed to?
I stress tested it,and cpu speed didn't dropped,but cpu speed is not still it's changing 3.6/3.8/3.5 etc
That's normal. CPUs haven't maintained a single clockspeed at all times since the Pentium 4 days.
Your CPU has a rated base speed of 3.1GHz and a rated boost of 3.8GHz, so when under load - when something CPU intensive is happening - anything in that range between 3.1GHz and 3.8GHz is perfectly normal.
Best as I can tell, your CPU is fine. Stuttering in games is probably just because your CPU isn't able to handle them - it's almost 10 years old and below the minimum requirements of modern games in 2023.
Ooooooh that makes sence,thank you
