Can hot exhaust damage a monitor?
Solved by Hinjima,
1 minute ago, nalfelein said:I forgot GPU width exists and can't comfortably use my side panel anymore. 3090 exhausts directly to the side of the bottom right of my 32 inch VA panel from like 15 cm away. It does get considerably hot, and is worsened by summer weather. Is this problematic? I can't really move the monitor since the desk is rather small. Googling this question gave me rather mixed results and im still not sure.
not enough to be cause of concern.
