Witch monitor is better help me pick pls
Go to solution Solved by Failure 101,
3 minutes ago, lazardif said:
ALIENWARE 34 CURVED QD-OLED GAMING MONITOR - AW3423DW OR
ROG Swift OLED PG27AQDM
Building new setup, i cant decide what monitor to buy from this 2, i want high qualiti HDR i never played on 21:9 so im afraid if i buy alienware maybe i would not like it and that would be costly mistake, plus i knew a lot of games don't support 21:9, but evry rewiew i watched they say Alienware is a beter monitor for adventure single player games wich i play the most, but i also play cod, pubg, dota, fortnite from time to time, watch movies, i don't care that much about hz is it 175hz or 240hz i don't think i can tell a difference, i also planing to start striming, i do have 7900xtx, ryzen 7700x, b650 steel legend, 6000mhz cl30 ddr5, m.2nvme 1tb so can anyone help me what to chose? Any recommendations?
The DW is QD-OLED while the QDM is just a normal OLED. You also get 21:9 with the DW. Also you should be getting the DWF instead of the DW
https://linustechtips.com/topic/1517747-witch-monitor-is-better-help-me-pick-pls/
I would go with the PG27AQDM if you’re not sure about 21:9, just make sure that if you’re going to start streaming that you have enough room for the chat and everything that comes with that, and if you don’t maybe think about getting the Alienware. About 175 vs 240 hz though, with your hardware you will probably be able to utilize 240 hz rather than 175. For me, I would go with the PG27AQDM.
| Mark Solutions as Solutions | Just Because Nobody's Replied Doesn't Mean Nobody's Thinking | Refresh Often| Bottleneck Calculators are BS|
Main System: CPU: Intel Core i5-12600K/ COOLER: Be Quiet! Pure Rock Slim 2/ RAM: 32GB (2x 16GB) Corsair Vengeance LPX DDR4 3600MHz/ GPU: MSI RTX 3070 LHR Ventus 2x OC/ SSD1: 512GB NVMe M.2 SSD & SSD2: SK Hynix P41 2TB/ Case: Fractal Pop! Air (Black RGB TG Clear Tint)/ PSU: EVGA SuperNOVA 750 P2/ MOBO: AsRock Z690 Phantom Gaming 4
Temps under load: CPU: Under Cinebench r23 looped for 30 minutes, temps reach around 60-67 C (140-152.6 F)
GPU: Under Fur Mark for 45 minutes, temps reach around 71-74 C (161.6-178.4 F)
Second System: CPU: Intel Core i7-4960x/ COOLER: Old Corsair 120mm AIO/ RAM: 32GB (4x 8GB) Corsair Vengeance DDR3 1600MHz/ GPU: AMD Radeon PRO W5700 GPU/ SSD: 250GB Samsung SATA SSD & HDD: WD Blue 500GB/ Case: Thermaltake Level 10 GTS/ PSU: Corsair RM1000X
Temps under load: CPU: Under Cinebench r23 looped for 30 minutes, temps reach around 60-65 C
GPU: Under Fur Mark for 45 minutes, temps reach around 69-73 C (156.2-163.4 F)
Laptop: Lenovo IdeaPad Gaming 3i 15IMH05 (Intel Core i5-10300H, 16GB DDR4 2933MHz, Nvidia GeForce GTX 1650 Ti, 500GB NVMe M.2 SSD & 500GB SATA SSD)
Temps under load: CPU: Under Cinebench r20 looped for 30 minutes, temps reach around 87-92 C (188.6-197.6 F)
GPU: Under Fur Mark for 45 minutes, temps reach around 81-84 C (177.8-183.2 F)
NAS: I converted an older Advantech PC used for X-Ray machines to hold a hard drive or two. CPU: i7-6700 with whatever cooler was in the Advantech chassis/ RAM: 32GB Generic DDR4-2666/ SSD: Samsung 250GB SATA SSD/ HDD: 2TB Seagate random HDD
Phone: iPhone SE 2 (2020 version)
I would personally choose the ROG Swift OLED PG27AQDM because I hate ultrawide monitors, and QD-OLED is new whereas regular OLED has matured.
From a really quick Google search, QD-OLED is more prone to burn-in than OLED, but I'm sure there's more to the story than reading a couple of sentences.
QD-OLED is only beneficial for color accuracy in very brightly-lit areas, and a higher peak brightness. It's a difference you would only notice if you were comparing OLED and QD-OLED side by side. Which means it's pointless, impractical difference. Get the OLED.
| Remember to mark Solutions! | Quote Posts if you want a Reply! |
| Tell us everything! Budget? Currency? Country? Retailers? | Help us help You! |
17 minutes ago, lazardif said:
can't go wrong with either, it's ur call base on aspect ratio, also the dwf is a better deal than the dw.
5950x 1.33v 5.05 4.5 88C 195w ll R20 12k ll drp4 ll x570 dark hero ll gskill 4x8gb 3666 14-14-14-32-320-24-2T (zen trfc)  1.45v 45C 1.15v soc ll 6950xt gaming x trio 325w 60C ll samsung 970 500gb nvme os ll sandisk 4tb ssd ll 6x nf12/14 ippc fans ll tt gt10 case ll evga g2 1300w ll w10 pro ll 34GN850B ll AW3423DW
9900k 1.36v 5.1avx 4.9ring 85C 195w (daily) 1.02v 4.3ghz 80w 50C R20 temps score=5500 ll D15 ll Z390 taichi ult 1.60 bios ll gskill 4x8gb 14-14-14-30-280-20 ddr3666bdie 1.45v 45C 1.22sa/1.18 io  ll EVGA 30 non90 tie ftw3 1920//10000 0.85v 300w 71C ll  6x nf14 ippc 2000rpm ll 500gb nvme 970 evo ll l sandisk 4tb sata ssd +4tb exssd backup ll 2x 500gb samsung 970 evo raid 0 llCorsair graphite 780T ll EVGA P2 1200w ll w10p ll NEC PA241w ll pa32ucg-k
prebuilt 5800 stock ll 2x8gb ddr4 cl17 3466 ll oem 3080 0.85v 1890//10000 290w 74C ll 27gl850b ll pa272w ll w11
They say qd-oled is easier to burn in, also asus has more brightness and better HDR qualiti, but on the other hand they say gaming on ultrawide is on another level, i never played on 21:9 and it would be expensive mistake if i buy it and don't like it, i think i go with asus, ty anyway
So qd-oled has lees brightness and worse HDR than asus and it can easier burn in? Well i go with asus than, i wanted to try 21:9 but it would be expensive mistake if I don't like it, it's better to stick to classic and familiar i gues
QD-OLED has a Quantum Dot layer that gives it better color accuracy, especially at higher brightness. It is also capable of getting brighter than OLED due to its different method of displaying colors.
But the improved colors, in my opinion, is a small difference compared to regular OLED.
Either is ok. What you need to decide is 16:9 or 21:9.
The Alienware is around 1.5 units of Asus. Both height is same.
For brightness is never an issue especially no issue for HDR content.
It is not as bright as mini-LED but it still bright enough even on normal lightning environment.
PC: AMD Ryzen 9 5900X, Gigabyte GeForce RTX 4090 OC 24G, X570 AORUS Elite WIFI Motherboard, HyperX FURY 32GB DDR4-3200 RGB RAM, Creative Sound Blaster AE-9 Sound Card, Samsung 970 Evo Plus M.2 SATA 500GB, ADATA XPG SX8200 Pro M.2 SATA 2TB, Asus HyperX Fury RGB SSD 960GB, Seagate Barracuda 7200RPM 3.5 HDD 2TB, Cooler Master MASTERLIQUID ML240R ARGB, Cooler Master MASTERFAN MF120R ARGB, Cooler Master ELV8 Graphics Card Holder ARGB, Asus ROG Strix 1000G PSU, Lian Li LANCOOL II MESH RGB Case, Windows 11 Pro (22H2).
Laptop: Asus Vivobook "A Bathing Ape" - ASUS Vivobook S 15 OLED BAPE Edition: Intel i9-13900H, 16 GB RAM, 15.6" 2.8K 120hz OLED | Apple MacBook Pro 14" 2023: M2 Pro, 16 GB RAM, NVMe 512 GB | Asus VivoBook 15 OLED: Intel® Core™ i3-1125G4, Intel UHD, 8 GB RAM, Micron NVMe 512 GB | Illegear Z5 SKYLAKE: Intel Core i7-6700HQ, Nvidia Geforce GTX 970M, 16 GB RAM, ADATA SU800 M.2 SATA 512GB.
Monitor: Samsung Odyssey OLED G9 49" 5120x1440 240hz QD-OLED HDR, LG OLED Flex 42LX3QPSA 41.5" 3840x2160 bendable 120hz WOLED, LG UltraGear Gaming Monitor 34" 34GN850 3440x1440 144hz (160hz OC) NanoIPS HDR, LG Ultrawide Gaming Monitor 34" 34UC79G 2560x1080 144hz IPS SDR, LG 24MK600 24" 1920x1080 75hz Freesync IPS SDR, BenQ EW2440ZH 24" 1920x1080 75hz VA SDR.
Input Device: Asus ROG Azoth Wireless Mechanical KeyboardAsus ROG Chakram X Origin Wireless MouseLogitech G913 Lightspeed Wireless RGB Mechanical Gaming Keyboard, Logitech G502X Wireless Mouse, Logitech G903 Lightspeed HERO Wireless Gaming Mouse, Logitech Pro X, Logitech MX Keys, Logitech MX Master 3, XBOX Wireless Controller Covert Forces Edition, Corsair K70 RAPIDFIRE Mechanical Gaming Keyboard, Corsair Dark Core RGB Pro SE Wireless Gaming Mouse, Logitech MK850 Wireless Keyboard & Mouse Combos.
Entertainment: LG 55" C9 OLED HDR Smart UHD TV with AI ThinQ®, 65" Samsung AU7000 4K UHD Smart TV, SONOS Beam (Gen 2) Dolby Atmos Soundbar, SONOS Sub Mini, SONOS Era 100 x2, SONOS Era 300 Dolby Atmos, Logitech G560 2.1 USB & Bluetooth Speaker, Logitech Z625 2.1 THX Speaker, Edifier M1370BT 2.1 Bluetooth Speaker, LG SK9Y 5.1.2 channel Dolby Atmos, Hi-Res Audio SoundBar, SONOS ACE, Technics AZ80, Technics A800E, Sony MDR-Z1R, Bang & Olufsen Beoplay EX, Sony WF-1000XM5, Sony WH-1000XM5, Sony WH-1000XM4, Apple AirPods MAX, Apple AirPods Pro 2, Samsung Galaxy Buds2, Nvidia Shield TV Pro (2019 edition), Apple TV 4K (2017 & 2021 Edition), Chromecast with Google TV, Sony UBP-X700 UltraHD Blu-ray, Panasonic DMP-UB400 UltraHD Blu-ray.
Mobile, Tablet & Smart Watch: Google Pixel 9 Pro XL (Obsidian) Apple iPhone 15 Pro Max (Natural Titanium), Apple iPad Pro 11" 2024 M4 (Space Black), Apple Watch Series 8 Stainless Steel with Milanese Loop (Graphite).
Others Gadgets: Asus SBW-06D2X-U Blu-ray RW Drive, 70 TB Ext. HDD, j5create JVCU100 USB HD Webcam with 360° rotation, ZTE UONU F620, Maxis Fibre WiFi 6 Router, Fantech MPR800 Soft Cloth RGB Gaming Mousepad, Fantech Headset Headphone Stand AC3001S RGB Lighting Base Tower, Infiniteracer RGB Gaming Chair
It's only brighter than LG WRGB OLED monitor, it certainly isn't brighter than a QD-OLED panel. Especially when it comes to colour volume (colour brightness.) This mean significantly dimmer looking day time scenes, WRGB OLED really struggles in game like Forza 5 where you are in a bright outdoor condition nearly all the time.
The PG27AQDM could still be better for your use case though as it has 240hz which can benefit esport title by a lot and while colours maybe a problem, it's still bright enough for an OLED.
