CPU die lapping
I've been watching several die lapping videos by LTT and drbauer and I've been wondering how exactly you know how much material you can safely remove from the die without actually damaging any of the integrated circuits in the die itself. Do you just look for guidance from the extreme overclockers who have sacrificed some cpus to determine how far you can go or is there some spec somewhere that will tell you how much of the die isn't occupied by any integrated circuits?
Current PC:
  • CPU
    Intel i9-12900KS
  • Motherboard
    Asus Rog Maximus Z690 Hero
  • RAM
    Corsair Vengeance DDR5-6600 MT/s, 2 x 16GB, (CL32-39-39-76, 1.40V), CMK32GX5M2X6600C32 for gaming or
    G.Skill Ripjaws DDR5-6000 MT/s, 2 x 32GB, (CL30-40-40-96, 1.40V), F5-6000J3040G32GX2-RS5K for heavy multitasking
  • GPU
    Aorus Xtreme Waterforce RTX 3090 TI
  • Case
    Corsair 7000D Airflow
  • Storage
    2 x 2TB WD Black sn850 SSDs
  • PSU
    EVGA Supernova 1600W P2, Fully Modular
  • Display(s)
    34" 1900R Alienware AW3418DW Black, 32" Samsung Odyssey G7 240Hz
  • Cooling
    Arctic Liquid Freezer ii 420, Built in 360mm gpu rad, 7 x 140mm Noctua NF-A14's (4 used as full case fan set, 3 used to upgrade CPU rad fans), 4 x 120mm Noctua NF-F12's (3 used to upgrade GPU rad stock fans, 1 used to fill last remaining case fan slot)
  • Keyboard
    Fidio Mechanical Gaming Keyboard
  • Mouse
    Asus Rog Spatha X
  • Sound
    SteelSeries Arctis Pro + Game DAC Wired Headset
  • Operating System
    Windows 11 Pro
  • PCPartPicker URL
In this video it looks like they're using a fixture to guide them to the correct depth:
When the fixture starts getting sanded on then they stop.  There really isn't a "safe" amount to take off because that was already done at the fab in a process called backgrinding....which uses a diamond slurry deal.  Sandpaper is extremely crude.
Workstation:  13700k @ 5.5Ghz || Gigabyte Z790 Ultra || MSI Gaming Trio 4090 Shunt || TeamGroup DDR5-7800 @ 7000 || Corsair AX1500i@240V || whole-house loop.
LANRig/GuestGamingBox: 9900nonK || Gigabyte Z390 Master || ASUS TUF 3090 650W shunt || Corsair SF600 || CPU+GPU watercooled 280 rad pull only || whole-house loop.
Server Router (Untangle): 13600k @ Stock || ASRock Z690 ITX || All 10Gbe || 2x8GB 3200 || PicoPSU 150W 24pin + AX1200i on CPU|| whole-house loop
Server Compute/Storage: 10850K @ 5.1Ghz || Gigabyte Z490 Ultra || EVGA FTW3 3090 1000W || LSI 9280i-24 port || 4TB Samsung 860 Evo, 5x10TB Seagate Enterprise Raid 6, 4x8TB Seagate Archive Backup ||  whole-house loop.
Laptop: HP Elitebook 840 G8 (Intel 1185G7) + 3080Ti Thunderbolt Dock, Razer Blade Stealth 13" 2017 (Intel 8550U)
I prefer trial by fire
Murder some cheapo celeron/athlon before lapping the cpu you wanna lap, ofc the dummy cpu gotta be from the same generation
if someones already lapped their die and can prove how much you can take off before the cpu dies then you can skip the trial by fire
As for the question of is it worth it?
Depends on how much effort you wanna put in, most ppl will say not worth it cause theyre average joes that wouldnt bother doing stuff like this anyways either out of fear, lazyness, or both
If i wasnt already gonna delid my cpu i wouldnt bother either, but if im already gonna delid my cpu i might aswell go and die lap cause i may aswell maximize temp drop
you start by googling how thick the silicone substrate is for your specific cpu family, next you take a starting measurement, then you sand it and take more measurements to see how much you removed and how much is left.
Still easier said than done and its only getting you to learn even pressure application. wood blocks and sandpapers are cheaper on that. You really need to nail the thickness as @OhYou_ stated, otherwise youre going to be out with dead daily driver. I wouldnt play doctor with it if it is your main desktop, especially on a pretty rare 12900KS. Getting contact frame in is like 60% of the battle anyway.
Press quote to get a response from someone! | Check people's edited posts! | Be specific! | Trans Rights
I am human. I'm scared of the dark, and I get toothaches. My. Name. Is. Frill.
I'm not actually considering die lapping for any of my current devices, the build that i would use that for would use direct die water cooling and is probably a few years down the road. Just want to learn more about the process.
Current PC:
  • CPU
    Intel i9-12900KS
  • Motherboard
  • RAM
  • GPU
  • Case
  • Storage
  • PSU
  • Display(s)
  • Cooling
  • Keyboard
  • Mouse
    Asus Rog Spatha X
  • Sound
  • Operating System
    Windows 11 Pro
  • PCPartPicker URL
It's not about how hard you are it's about recognizing when something is pointless to do.  Congrats you decrease your peak temp by 2 degrees.  What did that buy you?  You're not going to be able to step up the voltage any and even if you could, every chip for the last several years has been speed limited before it's temperature limited.   We're not even getting into the high likelihood that you're going to kill the silicon either immediately or down the road after it's thermal cycled a few times.
The only place this might be interesting is if you're doing it to a top end thermally limited chip like the new w9's.  But good luck blowing $5k to probably fuck it up.
