Best cpu cooler for am4
AngerIssuFlo
Go to solution Solved by SorryBella,
4 minutes ago, AngerIssuFlo said:
dead
Sorry for the language humor barrier there. I mean dead (on) stock, as in straightforwardly stock.
Also shit, i remember you. My recommendation is still the same, either the Gammaxx 400 or Hyper 212 Evo. As @jaslion and i say, theyre hard to install, but you fully get the value that you paid for, it performs better than your usual 92mm tower or stock clone flower cooler suspects in this budget.
Whats the best budget am4 cooler for about 15-30 euros.
dead stock cooler inside of the box. Unless if you have the upper end 105-125W chip like 5800X3D, the stock cooler will buy you a lot of time.
Also, which country in specific? most EU states sticks to Euro.
Press quote to get a response from someone! | Check people's edited posts! | Be specific! | Trans Rights
I am human. I'm scared of the dark, and I get toothaches. My. Name. Is. Frill.
Its not dead, it doesnt even come with cooler because with cooler its 50 euros expensiver. Btw im in the netherlands
dead
Whatevers the cheapest 4-6 heatpipe tower you can find, maybe an se 214 xt, gammax 400, assassin king/burst assassin, peerless assassin/phantom spirit 120, etc.
