Will 1 8 Pin EPS connector will be enough for MSI MPG B650 EDGE WIFI
Hi I want to buy the MSI MPG B650 EDGE WIFI but I don’t know if I’ll need to get a new power supply as well because mine only got 1 8 pin EPS connector and I saw the motherboard needs 2 I don’t know if it’s mandatory to use both. The cpu I’ll be using is Ryzen 7 7800X3D and I’ll overclock my ram to 6000 MHz. Thanks in advance.
That’s plenty of power for a 7800X3D.
Rig: i7 10700k @ 5.1Ghz, 4.8 Ring - - Z490 Vision G - - EVGA RTX 2080 XC Ultra @ 2025Mhz - - 4x8GB Vengeance Pro 3000Mhz 15-17-17-34 @ 3500MHz 16-19-19-38 - - Samsung 950 Pro 512 NVMe Boot + Main Programs - - Samsung 830 Pro 256 RAID 0 Lightroom + Photo work - - WD Blue 1 TB SSD for Games - - Corsair RM850x - - Sound BlasterX EA-5 - - EK Supremacy Evo - - XT45 X-Flow 420 + UT60 280 rads - - EK Full Cover GPU Block - - EK XRES RGB PWM - - Fractal Define S2 - - Acer Predator X34 -- Logitech G502 - - Logitech G710+ - - Logitech Z5500 - - LTT Deskpad
Headphones/amp/dac: Schiit Lyr 3 - - Fostex TR-X00 - - Sennheiser HD 6xx
Homelab/ Media Server: Proxmox VE host - - 512 NVMe Samsung 980 for VM's/Proxmox boot - - Xeon e5 2660 V4- - Supermicro X10SRF-i - - 128 GB ECC 2133 - - 10x4 TB WD Red RAID Z2 - - Corsair 750D - - Corsair RM650i - - Dell H310 6Gbps SAS HBA - - Intel RES2SC240 SAS Expander - - TreuNAS + many other VM’s
iPhone 14 Pro - 2018 MacBook Air
The EPS connector is good for 300 watts, the 7800x3d will consume maybe at most half of that. So it's enough.
Alright, thanks for responding
