Pny Geforce GTX 1080 Ti Blower Edition 11GB
hey i am buying new graphics card it is pny gtx 1080 ti blower edition so i am wondering how will it perform and will it be normal if the temp will be more than 80c
should perform like a stock 1080ti (if you dont have a bottlneck) however check the 5700xt as it can be found for similer cost and performs better (unless you need the extra vram)
It should perform like any other GTX 1080 ti.  It will be significantly louder than other types of cards due to the blower style cooler, make sure to have good case airflow.
ok thank you
ah ok i will see 5700xt as well
