Constant Stuttering in Games with massive fps drops and spike frametimes from 5ms upto 18ms
Hey All
Every single game I try to play seems to have hitches. The frametime spikes up causes a stutter and its easily noticeable and
getting to the point when trying to play games is just no longer fun. Happens on MW2 , BF2042 and PUBG And CSGO.
Does not matter what the settings are set to very low ultra its always there.
What I have done to try and fix the issue myself
Upgrade from a 3700x to a 5800x3d
Upgrade ram from Hyper x Predator 3200mhz kit to Corsair LPX 3600mhz kit
Fresh install of Windows 10 & 11 Pro With a full format of all drives
Fully rebuild the system to make sure everything is seated correctly
Run CSM/UFEI Both made no diffrence
Under volting the CPU & GPU
Set all fans in case & motherboard & gpu to 100%
Turn Gamemode off and on
Disable GPU Scheduling
Run games on low settings and normal settings
Check all temps CPU sits around 62c and gpu is 68c hotspot 78c
Change clock speeds of CPU to a locked base of 3500mhz and same to the gpu of 1800mhz
Limit framerates in games to 90fps 120fps and 144fps
Checked power supply and all voltages under load are normal and not changing. Powedraw from the wall is around 480w to 520w
XMP Off and on
SMT & SVM Off and on
TPM Settings Off and On
Bios Versions Tried
7B93v1J-2023-05-11
7B93v1I-2023-03-06
7B93v1F-2022-03-31
7B93v1D-2021-07-07
I am honestly all out of ideas at this point on what my next steps are. Do I just go back to intel or is it something i am doing wrong
Specs
CPU: AMD Ryzen 7 5800X3D
MB: MSI X570 Pro Carbon Wifi
Ram: Corsair Vengeance LPX 32GB 16X2 3600mhz C18
Cooler: H115i V2
GPU: Gigabyte RTX 3070 AMPERE
M.2: Crucial P2 1TB - Game Drive
M.2: Crucial P1 1TB - OS & Program Drive
PSU: Corsair RM750
Mouse: Logitech G502
Keyboard: Logitech G513
Thanks to everyone who has took time to read this and give some support!
25 minutes ago, TheJammie said:
Hey All
XMP Off and on
Bios Versions Tried
7B93v1J-2023-05-11
7B93v1I-2023-03-06
7B93v1F-2022-03-31
7B93v1D-2021-07-07
Specs
Cooler: H115i V2
PSU: Corsair RM750
What res are you playing on ?
At 1440P and above the RTX3070 may just lack VRAM...
System : AMD R9 5900X / X570 AORUS PRO/ 2x16GB Corsair Vengeance 3600CL18 ASUS TUF Gaming AMD Radeon RX 7900 XTX OC Edition GPU/ Phanteks P600S case /  Eisbaer 280mm AIO (with 2xArctic P14 fans) 0.5TB Sabrent Rocket + 2TB WD SN850 NVme Gen4 + 4TB Toshiba X300 HDD drives/ Corsair RM850x PSU/ 34" 120Hz 3440x1440p Alienware AW3420DW monitor / Logitech G915TKL keyboard (wireless) / Logitech G PRO X Superlight mouse
27 minutes ago, TheJammie said:
Hey All
Are you using the latest AMD chipset drivers?
https://www.amd.com/en/support/chipsets/amd-socket-am4/x570
XMP loaded? Loaded XMP stable?
Bottlenecking the GPU with 1080p or running 1440p?
Tried disabling MultiPlane Overlay MPO?
Windows updated? 10 or 11?
M.S.C.E. (M.Sc. Computer Engineering), Senior IT advisor in a hospital, 30 years of gaming, 20 years of computer enthusiasm, Geek, Trekkie, anime fan
  • Main PC: AMD Ryzen 7 5800X3D - EK AIO 360 D-RGB - Arctic Cooling MX-4 - Asus Prime X570-P - 4x8GB DDR4 3200 HyperX Fury CL16 - Sapphire AMD Radeon 6950XT Nitro+ - 1TB Kingston Fury Renegade - 1TB ADATA SX 6000pro  - 512GB ADATA SU800 - 960GB Kingston A400 - Seasonic PX-850 850W  - custom black ATX and EPS cables - Fractal Design Define R5 Blackout - Windows 11 x64 2022 - 3 Arctic Cooling P14 PWM PST - 5 Arctic Cooling P12 PWM PST
  • Peripherals: LG 32GK650F - Philips 226VL - Logitech G Pro X Superlight with Tiger Ice - White Shark Spartan X (TKL) - EndGame Gear MPC890 - Genius HF 1250B - Akliam PD4 - Sennheiser HD 560s - Truthear Zero - QKZ x HBB - 7Hz Salnotes Zero - Logitech C270 - Behringer PS400 - BM700  - Colormunki Smile - Speedlink Torid - Jysk Stenderup - LG 24x External DVD writer - Konig smart card reader
  • Networking: Asus RT-N18U - SpeedPort Plus - 35/7 Mbps vDSL - TP-Link TL-WA850RE - TP-Link 5-port 1Gbps switch
  • TV and gadgets: TCL 50EP680 50" 4K LED + Sharp HT-SB100 75W RMS - Samsung Galaxy Tab A8 10.1" - OnePlus 9 256GB - Olymous Cameda C-160 - GameBoy Color
  • Streaming/Server/Storage PC: AMD Ryzen 5 3600 - LC-Power LC-CC-120 - MSI B450 Tomahawk Max - 2x4GB ADATA 2666 DDR4 - 120GB Kingston V300 - Toshiba DT01ACA100 1TB - Toshiba DT01ACA200 2TB - 2x WD Green 2TB - Sapphire Pulse AMD Radeon RX 5700XT - 550W EVGA G3 SuperNova - Chieftec Giga DF-01B - Logitech G710+ - Roccat Kone Pure Military Desert strike - Logitech S-220
28 minutes ago, TheJammie said:
Do you use G hub for your logitech stuff? I've seen many issues with G hub in the past.
this wouldnt make sense for a game like CSGO
Recent build: Fractal Design - Torrent reviewMeshify C / The 1080TI Strix Noctua modDefine S X58 Xeon build  / Specs: i7-12700KF 5.1ghz/4.1Ghz - ASUS TUF Gaming RTX 3080 - Corsair vengeance 32GB 3600Mhz -  Gigabyte Z690 Gaming X d4 - Torrent Fractal Design white - EVGA 850W Supernova G2 80+ Gold - Noctua D15
Hey, Right now all my games are running 1080P On my list of things to grab is a new 1440p monitor but been spending so much trying to get to the bottom of the issue that I have not had the chance yet
Definetly bottlenecking the gpu the now with 1080P
XMP loaded is stable always pass memtest and everything thankfully. Even with changed ram kits the ram never really failed a test and never seems to drop in clocks or voltage.
Updated 10 and 11 with the latest updates that are available
I do have GHUB Installed to control them actually. Will test uninstalling it and see if that sorts the issue
And the chipset drivers? MPO?
Chipset drivers are installed. Just had to google what MPO was there as thats a new one for me. Going to go and edit the registry the now and give that a go hopefully thats the one thing i have forgot
The ones from AMD? Or are you referring to the old ones from MSI?
Tried disabling the Game Bar / Xbox bar?
My chipset drivers are directly from AMD website as the MSI one has not been updated in a few months
Xbox game bar is currently still disabled from turning off gamemode and everything
Had the same issue. This fixes it for me overall on Ryzen 5500.
Press quote to get a response from someone! | Check people's edited posts! | Be specific! | Trans Rights
I am human. I'm scared of the dark, and I get toothaches. My. Name. Is. Frill.
Ok, that's great.
SSD-s using the latest firmware(s)?
SSD-s trimmed (optimized)?
Maybe checked other drivers for updates with something like Iobit Driver Booster?
It's great for updating Realtek drivers (network, audio).
8 minutes ago, 191x7 said:
Ok, that's great.
Yeah they are on the latest firmware and just done another optimization there so hoping with that we are all good. Will report back in 5 minutes
11 minutes ago, SorryClaire said:
Had the same issue.
Ive tried a few type of ram timings myself as well as buying new kits of ram and nothing really fixed it for me ram wise sadly
15 minutes ago, 191x7 said:
Ok, that's great.
So with all that done again. Increased FPS however sadly the spikes in frametime and stutters are still there image.png.7d7838c752f65fefd864535f42ff5843.png
Have you checked your DPC latency?
At the time of the spikes, does the Windows Reliability Monitor say something happened?
Tried with older nVidia drivers? Tried the newest (supposedly a new one came out maybe a couple of days ago)?
Have you tried using all default settings, including the Bios settings?
Does your GPU use the latest available vBios/firmware?
Running Above 4G decoding and Resizable BAR?
DPC Latency is around 898 - 1096 while gaming. Which I am not sure if that is good or not.
Windows Reliability Monitor says absoloutly nothing either sadly.
Default bios has been tried with every bios version i have tried.
vBios has been flashed to the only update there is for my card. As i needed flashed to be able to enable resizable bar which is enabled along with 4G decoding.
I'm running the latest driver there is the now but ive tried a good lot of drivers all the way back to release day drivers and known good ones.
Have you checked with Iobit Driver Booster?
Have you tried executing these commands in CMD as admin or in Power Shell or Windows Terminal?
DISM /Online /Cleanup-Image /RestoreHealth
SFC /scannow
Are you locking your framerate or letting it run wild?
Using the latest driver for your monitor(s)?
Just tried your solution and all though it did gain me 8fps more in one title I have been using to test all this it sadly did not fully remove the stuttering and high spikes in render time
SFC /scannow
Just installed it and let it do its thing there a few updates but not a lot,
IoBit took care of the driver for the monitor just there the now but it never made any changes to the performance.
Ive tried locking the framerate to 90 120 144 and letting it run wild and no matter what it is set too its just the same.
Ive ran those commands before and also freshly install windows 10 & 11 and still have keep running into the same wall with the system for some reason.
Driver Booster just installs the generic monitor drivers, that tells me you're not using the appropriate monitor drivers for your monitor(s).
Which manufacturer and model?
There is no driver or firmware for my monitor at all. Like its a pretty basic monitor Acer XF240H
  • 3 weeks later...
Asking here again.
When i swapped out the PSU i swapped it out for another 750w. When the games are stuttering these seem to drop at the same time.
Do i need more than a 750w PSU for my system
Specs Posted Below Again
Specs
Cooler: H115i V2
PSU: Corsair RM750
