Problem with usb-a when conecting two external hard drives in differente ports!
48 minutes ago, dreis86 said:one is a 2.5" Toshiba 4TB USB 3.2 Canvio Ready and and the other is a wd elements 1tb , but i try with other external hard drives is always the same results. could it be a faulty pair of ports? they are connected in diferent ports and after disconecting and connecting they keep connect
Motherboard USB ports aren't independent of each other, they are grouped into specific USB controllers, most obviously seen these days by different ports supporting different speeds. The trick with a problem like this is to try different ports so the drives are on different controllers, or avoid USB powered drives entirely as like mentioned above they tend to have very high startup and write currents.
Most 2.5" drives current ratings are higher than even USB 3, its amazing they work at all and my guess is because those ratings are mostly about the startup current and the fact USB ports are effectively bundled together, each controller can output more than the USB 3 rating - except if you end up with two drives on the same USB controller/power plane.
