How to lock frame rate for ASSASSINS CREED Syndicate
G9XFTW
Go to solution Solved by G9XFTW,
4 minutes ago, emothxughts said:
Go to Radeon Software, then the Global Graphics tab, then look for either Radeon Chill or Frame Rate Target Control, then set the FPS limit to 60fps.
I dont use RADEON software as it was causing suttering on my PC for over a year. So I had to get rid off it.
I used Riva statistics tuner instead to cap my global frame rate.
MY gpu is crunching out 100+ fps and I just dont need the heat and other challenges that come with it.
How do I lock the framerate to 60 on an AMD radeon GPU?
  1. Tug Of War
  2. Kiss
  3. E.MO.TION (& Side B)
  4. Dedicated (& Side B)
  5. The Loneliest Time & The Loveliest Time
PC specs:
CPU: AMD Ryzen 5 3600 3.6 GHz 6-Core Processor
CPU Cooler: Deepcool GAMMAXX 400 V2 64.5 CFM CPU Cooler
Motherboard: ASRock B450M Steel Legend Micro ATX AM4 Motherboard, BIOS P4.60
Memory: PNY XLR8 16 GB (2 x 8 GB) DDR4-3200 CL16 Memory
Storage: HP EX900 500 GB M.2-2280 PCIe 3.0 X4 NVME Solid State Drive, PNY CS900 1 TB 2.5" Solid State Drive
Video Card: Colorful Battleax RTX 2060 Super 8 GB, driver 531.79
Power Supply: Cooler Master MWE Bronze V2 650 W 80+ Bronze Certified ATX Power Supply
Operating System: Microsoft Windows 10 Pro
Wireless Network Adapter: TP-Link TL-WN881ND 802.11a/b/g/n PCIe x1 Wi-Fi Adapter
Monitor: LG 24MP400-B 24.0" 1920 x 1080 75 Hz Monitor
Keyboard: Logitech G413 Carbon Wired Gaming Keyboard
Mouse: Logitech G102 Prodigy Wired Optical Mouse
