Is there any chance a MERC card will fit inside a Fractal Define C?
Hello,
I wanted to upgrade the GPU to a MERC, but my case is Fractal Define C: https://www.fractal-design.com/products/cases/define/define-c-tempered-glass/
And it says max GPU length is 315mm with front fan. Now if I remove the front fan, it's around extra 2cm so 335mm~
But the MERC card length is 34cm, for example: https://www.xfxforce.com/shop/xfx-speedster-merc-319-amd-radeon-tm-rx-6950-xt-black#2
Now sometimes those dimensions are not accurate, so maybe someone here had an experience with a similar setup?
Thanks
1 minute ago, Filingo said:
Hello,
Thanks
It won't fit
I would get this 6950 xt that should fit with the front fan mounted and if it doesn't then just remove the front fan PowerColor Red Devil OC Radeon RX 6950 XT 16 GB Video Card (AXRX 6950XT 16GBD6-3DHE/OC) - PCPartPicker
Mark the solution as solution
Take my advice with a grain of salt. Not too much tho, we don’t want ourselves getting dehydrated do we?
PC Specs: Black on white, Team Red+Green by Filpo - AMD Ryzen 5 5600, GeForce RTX 3060 12GB, Corsair 4000D Airflow ATX Mid Tower - PCPartPicker
CPU: R5 5600 CPU Cooler: Arctic Liquid Freezer ii 280 Mobo: B550 Gaming Plus RAM: 2 x 8 3200mhz LPX  SSD: P5 Plus 500GB Secondary SSD: Kingston A400 960GB GPU: MSI RTX 3060 Gaming X Case: 4000D airflow Fans: 2x Noctua P12 redux 1700, 1x Arctic P12, 1x Corsair LL120 PSU: RM850 Monitor: Samsung C22F Mouse: Logitech G203 Keyboard: Royal Kludge RK61
Two reasons to why you’ve scrolled down here 1. You’re curious 2. I’ve got a stalker 👀
Just now, filpo said:
It won't fit
thanks. They are generally more expensive but I will maybe wait for a sale then
Also, in general, which is better? The XFX MERC or the Red Devil? I just really like the look of the MERC
They both perform around the same. The XFX does look better but they perform the same. I would say that the red devil isn't that bad and you can go for it anytime and I personally quite like the look of the red devil but that's your preference.
