Advice in setting up XMP - DDR5 new system
Solved by RONOTHAN##,
7 hours ago, chacha1988 said:Thank you, I shop on a french website called Top Achat : https://www.topachat.com/accueil/index.php
Could also look on amazon.fr .. if french language doesn't scare you
I'd greatly appreciate the help
I've used this exact kit, it's pretty good:
This would also work:
https://www.amazon.fr/dp/B0B2S8SB3C?tag=pcp09-21&linkCode=ogi&th=1&psc=1
https://www.amazon.fr/dp/B0B2TCR7YP?tag=pcp09-21&linkCode=ogi&th=1&psc=1
https://www.amazon.fr/dp/B0BFG9VTKL?tag=pcp09-21&linkCode=ogi&th=1&psc=1
The Flare X5 kit is preferred as it would be EXPO and that does have a tendency to work better with AMD, though if you want to save the ~$10 and get the Ripjaws kit I wouldn't blame you.
