psu use in different region and compatibility with other building components?
25 minutes ago, Andersen7 said:use this psu within china mainland, which standardize the voltage of 220v, without any issues.
They have automatic switching voltage, as standard since 2010s. If you have to switch a PSU voltage manually, throw it away.
25 minutes ago, Andersen7 said:If there's need to purchase other cable/adapters/converters, can anyone give me some recommended these cables/adapters/converters links on amazon or just their product name to search for ?
C13 to (insert your plug type here)
27 minutes ago, Andersen7 said:can you give me some selection on my case to properly wrap all these things up with pretty airflow and transparent panel to see the rgb of motherboard?
Depends on what Amazon China has in stock right now. Check out the case review playlist by Gamers Nexus to find some goodies.
