Case recommendations with great airflow?
Just now, HopelessGPU said:Looking into replacing my P600s case since the metal where your supposed to screw in the gpu to support it is bent. I don't really care about looks that much as long as it is great quality and functions well for my needs.
The pc parts going into the pc are
mobo = b660 gaming x ax ddr4
cpu cooler = NH-D15 premium cooler
GPU= RTX 3080 ftw3 ultra gaming 10gb
PSU = Corsair RMe Series RM1000e fully modular
Fans = Would prefer if it can hold 6 or more 140mm fans
Price = something that's similar in price to the p600s
Let me now if you need more information so I can edit the post so I can add more information that would be helpful to know.
Do you need a vertical mount? If you don't then get this H7 flow NZXT H7 Flow ATX Mid Tower Case (CM-H71FB-01) - PCPartPicker
