PC Hard Locking up/ Freezing With Graphical Glitches - Help!
Solved by 191x7,
Check if there's a newer bios than yours and flash it if there is.
Install the latest chipset drivers. Download from AMD, not Gigabyte.
Check your SSD for a firmware update.
Use
Dism /online /cleanup-image /restorehealth
Sfc /scannow
to check your Windows.
Retest your RAM.
4
john b ·
Posted in Phones and Tablets3 -
NukoTi ·
Posted in Troubleshooting4 -
play_circle_filled
Latest From ShortCircuit:
The World's Fastest CPU (Technically...) - Intel i9-14900KS
