Need help with my first build, especially the SSDs
Budget (including currency): About $1500-ish USD
Country: Mexico
Games, programs or workloads that it will be used for: I'll be using the PC for gaming, watch anime, streaming, and will be doing some productivity work like photoshop, illustrator, web development stuff, video editing and also lastly I wanna do some 3D rendering, game development and things like that, not professional level, just learning them and maybe as a hobby level for now since a 3060 is the most I can pay with my budget (I think)
Other details (existing parts lists, whether any peripherals are needed, what you're upgrading from, when you're going to buy, what resolution and refresh rate you want to play at, etc): This is my first time building a gaming pc or building a PC at all, my old PC was an AIO so theres nothing I can reuse unfortunately. 1080p is good enough for me and I'd like to be able to play most AAA games and upcoming games like Blue Protocol and maybe some other MMO with decent fps like maybe 60-80 or something like that. I dont have any gaming peripherals so if possible to include some, would be great but if the budget doesn't allow it, at least I'll need speakers or a headset since the monitor im buying has no audio.
With the little knowledge I have, and since I didnt have many choices in terms of components, this is what I could come up with, if theres anything I should change or if theres something incompatible, please let me know
CPU: i5-12400
CPU Cooler: Deepcool AG400
Motherboard: MSI Pro B660M-A Wifi DDR4 / MSI Mag B660M Mortar DDR4 (Cause the last MSI Pro just got sold in the store I'm gonna be buying)
RAM: Kingston Fury Beast RGB DDR4 3200 CL16 XMP 2x8GB
SSD OS + Programs: 512GB Kingston KC3000 or XPG S70 Blade or Adata Gammix S11 Pro
SSD Games and Storage: 1TB Kingston KC3000 or Spectrix S40G RGB
GPU: Asus Tuf Gaming V2 OC LHR 3060 12GB
PSU: XPG Core Reactor 750W 80+ Gold Full Modular
Case: Deepcool CK560 White
Monitor: Gigabyte 24'' G24F 2 IPS, 165hz
Not sure if I should buy thermal paste or not, and I couldnt get a cheap case with better airflow than that CK560, I hope thats enough for this build, I could get a Deepcool CC560 which is slightly cheaper but doesnt look like airflow is better, and it doesnt have RGB, only LED. Also I wasnt sure about the SSD's the selection was really small, I chose the KC3000 for the OS drive because I heard is really reliable and has good endurance but if the S11 Pro is reliable and has good endurance for an OS, thats cheaper and the second SSD, I dont know if I could get something cheaper so I could have some leftovers to buy a headset and a mouse, maybe an SN570? or even a Kingston NV2 but I heard its really bad.
About the PSU, I was planning to get a corsair RM850 white but its out of stock now, so I went for the Core Reactor, if the 750w and the 850w are at the same price, should I get the 850w or just go with the 750?
Thanks for the help!
Country: Mexico
CPU: i5-12400
Just get a 2TB M.2 NVME SSD. No need to complicate that part of the build. If you need/want to partition the drives for reasons, then you'll want at least 1TB for the O.S. and 1-2TB for the games and productivity work.
https://pcpartpicker.com/list/hpvmnt
CPU: Intel Core i5-13500 2.5 GHz 14-Core Processor  ($247.98 @ Newegg)
CPU Cooler: NZXT T120 RGB 50.18 CFM CPU Cooler  ($59.99 @ Amazon)
Motherboard: MSI MAG B760 TOMAHAWK WIFI ATX LGA1700 Motherboard  ($199.99 @ Amazon)
Memory: Corsair Vengeance 32 GB (2 x 16 GB) DDR5-5600 CL36 Memory  ($84.99 @ Newegg)
Storage: Western Digital Black SN770 1 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  ($54.99 @ Amazon)
Storage: Western Digital Black SN770 2 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  ($109.99 @ Newegg)
Video Card: MSI GeForce RTX 3060 Ventus 2X 12G GeForce RTX 3060 12GB 12 GB Video Card  ($289.99 @ Amazon)
Case: Deepcool CK560 ATX Mid Tower Case  ($89.99 @ Amazon)
Power Supply: Corsair RM750 750 W 80+ Gold Certified Fully Modular ATX Power Supply  ($119.99 @ Amazon)
Monitor: Gigabyte G24F 2 23.8" 1920 x 1080 180 Hz Monitor  ($144.99 @ Amazon)
$1402.89
Am I still to create the perfect system?! ~ Clu
Keep your expectations low, boy, and you will never be disappointed. ~ Kratos
$1402.89
This build is good but I would go with this @Aquastripe
There's a 4070 in this build which will defo be better than the 3060
PCPartPicker Part List: https://pcpartpicker.com/list/BbM6Tn
CPU: AMD Ryzen 7 5700X 3.4 GHz 8-Core Processor  ($174.99 @ Newegg)
CPU Cooler: Thermalright Peerless Assassin 66.17 CFM CPU Cooler  ($39.90 @ Amazon)
Motherboard: MSI B550-A PRO ATX AM4 Motherboard  ($139.99 @ Amazon)
Memory: Corsair Vengeance LPX 32 GB (2 x 16 GB) DDR4-3200 CL16 Memory  ($64.98 @ Amazon)
Storage: Western Digital Black SN770 1 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  ($52.99 @ Newegg)
Video Card: Asus DUAL GeForce RTX 4070 12 GB Video Card  ($599.99 @ ASUS)
Case: Deepcool CC560 ATX Mid Tower Case  ($66.98 @ Newegg)
Power Supply: Thermaltake Toughpower 750 W 80+ Gold Certified Semi-modular ATX Power Supply  ($102.99 @ Newegg)
Monitor: Dell G2422HS 23.8" 1920 x 1080 165 Hz Monitor  ($169.49 @ Amazon)
Total: $1522.29
Generated by PCPartPicker 2023-05-29 03:32 EDT-0400
Mark the solution as solution
Take my advice with a grain of salt. Not too much tho, we don’t want ourselves getting dehydrated do we?
PC Specs: Black on white, Team Red+Green by Filpo - AMD Ryzen 5 5600, GeForce RTX 3060 12GB, Corsair 4000D Airflow ATX Mid Tower - PCPartPicker
CPU: R5 5600 CPU Cooler: Arctic Liquid Freezer ii 280 Mobo: B550 Gaming Plus RAM: 2 x 8 3200mhz LPX  SSD: P5 Plus 500GB Secondary SSD: Kingston A400 960GB GPU: MSI RTX 3060 Gaming X Case: 4000D airflow Fans: 2x Noctua P12 redux 1700, 1x Arctic P12, 1x Corsair LL120 PSU: RM850 Monitor: Samsung C22F Mouse: Logitech G203 Keyboard: Royal Kludge RK61
Two reasons to why you’ve scrolled down here 1. You’re curious 2. I’ve got a stalker 👀
Total: $1522.29
Well OP did say 1500'ISH, but I try not to hit or exceed max budget (or max budget range).
If you are fine with 60-80 FPS, you don't really need 180 Hz.
With the RTX 3060 I would go for a 1440p 75 Hz 27 inch monitor.
Personally I use the RTX 2070, which has about the same performance and I bet you will never want to go back to 1080p.
My build:
CPU
Intel Core i7 9700 8x 3.00GHz So.1151
CPU cooler
be quiet! Shadow Rock Slim
Motherboard
MSI B360-A PRO Intel B360 So.1151 Dual Channel DDR4 ATX
RAM
16GB (4x 4096MB) HyperX FURY black DDR4-2666
GPU
8GB Gigabyte GeForce RTX2070 WindForce 2X 3xDP/HDMI
SSD
500GB Samsung 970 Evo Plus M.2 2280
HDD
4000GB WD Red WD40EFRX Intellipower 64MB 3.5" (8.9cm) SATA 6Gb/s
Power Supply
bequiet! Straight Power 750W Platinum
Case
Fractal Design Define R6
3x bequiet! Silent Wings 3 PWM
60-80 fps, but I'm sure they could go higher. That 180Hz is also for smoother scrolling, so a 60hz or 75hz monitor wouldn't be good.
Thanks everyone, those builds look really amazing, especially the amount of ssd storage, unfortunately in my country it exceeded my budget but I ended up getting a 2tb ssd for now instead of the 1 512gb + 1 1tb i was planning to get in the beginning, I'll try to get a second 2 tb in a couple of months. The monitor, I was okay with something lower than 180hz but the reason why I chose to go with that gigabyte monitor was because it was the cheapest i could find that had ips which i needed for graphic design and stuff like that. I am currently having some audio issues with the monitor though
This monitors pretty good, doesn't have built in speakers tho LG 24GN650-B 24.0" 1920 x 1080 144 Hz Monitor (24GN650-B) - PCPartPicker
