Monitor color format is RGB and not sRGB
Blqckqut
Go to solution Solved by si1enze,
That looks normal/correct.
Hello!
i am looking for an explenation/fix for this
i tried seeing if sRGB and RGB are different things but i found nothing about it.
as you can see it is only RGB, with SDR
color profile is also just generic PnP monitor.
device manager just says generic monitor.
i checked the website and there was no .ICC profile sadly, and it didnt come with a disc.
my monitor is: G-MASTER GB2770QSU-B1
https://iiyama.com/gl_en/products/g-master-gb2770qsu-b1/
how do i fix this and make my monitor function properly, it all seems fine but just a lil paranoid
Thank you.
Dont forget to mark as solution if your question is answered
Note: My advice is amateur help/beginner troubleshooting, someone else can probably troubleshoot way better than me.
- I do have some experience, and I can use google pretty well. - Feel free to quote me I may respond soon.
Join team Red, my apprentice
STOP SIDING WITH NVIDIA
Setup:
Ryzen 7 5800X3DSapphire Nitro+ 7900XTX 24GB / ROG STRIX B550-F Gaming / Cooler Master ML360 Illusion CPU Cooler / EVGA SuperNova 850 G2 / Lian Li Dynamic Evo White Case / 2x16 GB Kingston FURY RAM / 2x 1TB Lexar 710 / iiYama 1440p 165HZ Montitor, iiYama 1080p 75Hz Monitor / Shure MV7 w/ Focusrite Scarlett Solo / GK61 Keyboard / Cooler Master MM712 (daily driver) Logitech G502-X (MMO mouse) / Soundcore Life Q20 w/ Arctis 3 w/ WF-1000XM3
CPU OC: -30 all cores @AutoGhz
GPU OC: 3Ghz Core 2750Mhz Memory w/ 25%W increase (460W)
5800X3D -30 CO | 7900 XT | 2x32Gb Vengeance @ 3600 | MSI X470 | Sabrent Rocket 512 | 2x1Tb Vulcan T-Force | Seasonic Focus GX-750 Gold
Dell S3220DGF - curved 32" 1440p 165Hz
SRGB stand for Standard RGB, that's the 'RGB' you saw. Windows don't recognise any other colours in SDR colour space anyway.
