Is my case fan configuration good?
aromasn
FRONT 2 140mm 1200rpm fans
REAR 1 120mm 1500rpm fan
TOP 2 120mm 1500rpm fans
I want to know if this config is good for positive air pressure and in general.
We need to know at your config and direction of flow for the fans. Preferably the brand and model of fans, too.
I've been using computers since around 1978, started learning programming in 1980 on Apple IIs, started learning about hardware in 1990, ran a BBS from 1990-95, built my first Windows PC around 2000, taught myself malware removal starting in 2005 (also learned on Bleeping Computer), learned web dev starting in 2017, and I think I can fill a thimble with all that knowledge. 😉 I'm not an expert, which is why I keep investigating the answers that others give to try and improve my knowledge, so feel free to double-check the advice I give.
My phone's auto-correct is named Otto Rong.🤪😂
What's your fans orientation ? Usually front are intake, top/rear exhaust
Then you will rather have negative pressure, more oiutflow than inflow, unless you slow down the exhaust fans to 800/1000 rpm - and they'll be quieter too
System : AMD R9 5900X / Gigabyte X570 AORUS PRO/ 2x16GB Corsair Vengeance 3600CL18 ASUS TUF Gaming AMD Radeon RX 7900 XTX OC Edition GPU/ Phanteks P600S case /  Eisbaer 280mm AIO (with 2xArctic P14 fans) / 2TB Crucial T500  NVme + 2TB WD SN850 NVme + 4TB Toshiba X300 HDD drives/ Corsair RM850x PSU/  Alienware AW3420DW 34" 120Hz 3440x1440p monitor / Logitech G915TKL keyboard (wireless) / Logitech G PRO X Superlight mouse / Audeze Maxwell headphones
front are intake and the rest are exhaust
front and rear are fans included in lianli lancool 205 mesh and top fans are deepcool rf120 fs
top intake would be a better route here, because youll definitely have negative pressure with this setting.
Press quote to get a response from someone! | Check people's edited posts! | Be specific! | Trans Rights
I am human. I'm scared of the dark, and I get toothaches. My name is Frill. Don't pretend not to see me. I was born from the two of you.
As @PDifolco and @SorryClaire have indicated, you've got it set up for negative pressure. You'll get more dust, so keep it clean, or you'll need to rearrange the fans to make sure you're pulling more air in.
Are you air cooling your cpu or water cooling it?
If your air cooling it then turn those top two fans around as intake fans and keep that back fan as exhaust.
If your water cooling it keep those two top fans as exhaust on your rad and turn your back fan around as an intake
Message me on discord (bread8669) for more help
Current parts list
CPU: R5 5600 CPU Cooler: Stock
Mobo: Asrock B550M-ITX/ac
RAM: Vengeance LPX 2x8GB 3200mhz Cl16
SSD: P5 Plus 500GB Secondary SSD: Kingston A400 960GB
GPU: MSI RTX 3060 Gaming X
Fans: 1x Noctua NF-P12 Redux, 1x Arctic P12, 1x Corsair LL120
PSU: NZXT SP-650M SFX-L PSU from H1
Monitor: Samsung WQHD 34 inch and 43 inch TV
Mouse: Logitech G203
Keyboard: Rii membrane keyboard
Damn this space can fit a 4090 (just kidding)
air cooling
can i use one of the top fan as intake and the other as exhaust or will that create air flow issues?
1 minute ago, Quebls said:
air cooling
It'll be a bit weird but it's alright. I would put the one that's closer to the front as intake and the one that's further back as exhaust
Current parts list
okay thanks a lot everyone. I've finally settled on this config
2 front intake
1 top intake
1 top exhaust
1 rear exhaust
