Building my first PC need help 700$ budget
Budget (including currency):  700 USD
Country: USA
Games, programs or workloads that it will be used for: valorant, battlefield 5, Final Fantasy XV
Looking to start gaming again current parts are very outdated from 2014. I want to reuse the case and maybe the power supply not sure.
case: NZXT CA-H500B-B1
Power supply:seasonic ss-620gm active pfc f3
Monitor is: thinkvision t32p-20
can I reuse these two parts to save some money and spend on other parts?
Im also not knowledge on pc parts, can someone help me pick them out for best performance.
PCPartPicker Part List
CPU: *AMD Ryzen 5 5600 3.5 GHz 6-Core Processor  ($124.99 @ Newegg)
CPU Cooler: *Deepcool AG400 75.89 CFM CPU Cooler  ($21.99 @ Amazon)
Motherboard: *ASRock B550M Pro4 Micro ATX AM4 Motherboard  ($106.99 @ Amazon)
Memory: *TEAMGROUP T-Force Vulcan Z 16 GB (2 x 8 GB) DDR4-3200 CL16 Memory  ($35.49 @ Newegg)
Storage: *Crucial P3 Plus 1 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  ($51.99 @ Adorama)
Video Card: *Gigabyte EAGLE Radeon RX 6600 8 GB Video Card  ($179.99 @ Newegg)
Operating System: *Microsoft Windows 11 Home OEM - DVD 64-bit  ($99.99 @ Newegg)
Total: $621.43
Generated by PCPartPicker 2023-05-25 23:57 EDT-0400
if my google-fu are correct that thing is almost time for replacement. What year did you buy it? Any plans of replacing it later on?
Press quote to get a response from someone! | Check people's edited posts! | Be specific! | Trans Rights
Self Introduction and Current Rig
Hi, have you seen Hoshino Ai recently? Shes not missing, i just thought you should search her on the Internet.
I dont mind replace/upgrade it, just thought I could reuse it. I do want to reuse the case tho
Thats good then! At 10-15 years from the first turn on you should consider replacing PSU or keeping close eye on it due to cap degradation, but yeah itll be fine for now to not replace it.
CPU: Intel Core i5-12600K 3.7 GHz 10-Core Processor  ($199.99 @ Amazon)
CPU Cooler: Thermalright Assassin King SE 66.17 CFM CPU Cooler  ($24.90 @ Amazon)
Motherboard: MSI PRO Z690-P DDR4 ATX LGA1700 Motherboard  ($128.00 @ Newegg)
Memory: Silicon Power GAMING 32 GB (2 x 16 GB) DDR4-3200 CL16 Memory  ($49.97 @ Amazon)
Storage: TEAMGROUP MP33 PRO 2 TB M.2-2280 PCIe 3.0 X4 NVME Solid State Drive  ($79.98 @ Amazon)
Video Card: MSI MECH 2X OC Radeon RX 6650 XT 8 GB Video Card  ($239.99 @ Newegg)
Case: NZXT H500 ATX Mid Tower Case  (Purchased For $0.00)
Power Supply: SeaSonic M12II 620 W 80+ Bronze Certified Fully Modular ATX Power Supply  (Purchased For $0.00)
Total: $722.83
Generated by PCPartPicker 2023-05-26 00:32 EDT-0400
I would activate Windows 11 later on, but this is a good 1080p build at sub 1K.
Total: $722.83
There's no M.2 heatsink that comes with that board and I can think of better coolers than that $20 four pipe cooler for that unlocked cpu. If you're going to go with a 12 gen build with a $700 budget then look at the 12400F paired with that cpu cooler and a board with a M.2 heatsink.
https://pcpartpicker.com/product/pzstt6/msi-mag-b660m-mortar-wifi-ddr4-micro-atx-lga1700-motherboard-mag-b660m-mortar-wifi-ddr4
running sinkless on the 1TB version right now. It doesnt go as hot as you might think just doing normal tasks, id only concern it when its running insanely artificial load like read and writing for machine learning or heavy seed-leech in a p2p data transfer. But yeah that board is also pretty solid pick year-round. OP doesnt mention heavy CPU bound load as an issue but i do liked the AG400 pick instead.
