Are there smart home plugs that run on 5GHz?
phatrattyy
Go to solution Solved by AbydosOne,
7 minutes ago, phatrattyy said:
On Amazon, I only seem to see 2.5 GHz compatible smart plugs.
I'm not aware of any... 5/6GHz trades range for speed, which is somewhat counter to the M.O. of IoT/smart devices. I doubt there will be any soon, TBH.
8 minutes ago, phatrattyy said:
I wasn't sure whether I was supposed to post this in hobby electronics or general...
Networking would be my pick.
On Amazon, I only seem to see 2.5 GHz compatible smart plugs. My internet is only on the 5ghz bandwidth. I want to be able to turn on and off specific lights with my voice by plugging their cables into smart plugs into the wall. Is there a way to do this? I wasn't sure whether I was supposed to post this in hobby electronics or general...
Main System (Byarlant): Ryzen 7 5800X | Asus B550-Creator ProArt | EK 240mm Basic AIO | 16GB G.Skill DDR4 3200MT/s CAS-14 | XFX Speedster SWFT 210 RX 6600 | Samsung 990 PRO 2TB / Samsung 960 PRO 512GB / Crucial MX500 2TB / Crucial MX500 500GB / WD White 7200RPM 8TB | Corsair RM750X | Intel X540-T2 10G NIC | Inateck USB 3.0 Card | Hyte Y60 Case | Dell U3415W Monitor | Keychron K4 Brown (white backlight)
Laptop (Narrative): Lenovo Flex 5 81X20005US | Ryzen 5 4500U | 16GB RAM (soldered) | Vega 6 Graphics | SKHynix P31 1TB NVMe SSD | Intel AX200 Wifi (all-around awesome machine)
TrueNAS Server (Veda): Xeon E3-1241v3 | Supermicro X10SLL-F | Corsair H60 | 32GB Micron DDR3L ECC 1600MHz | 4x 10TB WD Whites / 4x 14TB Seagate Exos / 2x 1TB HGST 2.5" / 2x Samsung PM963a 960GB SSD / 1x Kingston 16GB SSD | Seasonic Prime Fanless 500W | Mellanox ConnectX-3 10G NIC | LSI 9207-8i HBA | Fractal Design Node 804 Case (side panels swapped to show off drives)
Media Center/Video Capture (Jesta Cannon): Ryzen 5 1600X | ASRock B450M Pro4 R2.0 | Noctua NH-L12S | 16GB Crucial DDR4 3200MT/s CAS-22 | EVGA GTX750Ti SC | UMIS NVMe SSD 256GB / Seagate 1.5TB HDD | Corsair CX450M | Hauppauge ImpactVCB-PCIe | Mellanox ConnectX-2 10G NIC | LG UH12NS30 BD-ROM | Silverstone Sugo SG-11 Case
Camera: Sony ɑ7II w/ Meike Grip | Sony SEL24240 | Samyang 35mm ƒ/2.8 | Sony SEL50F18F | Sony SEL2870 (kit lens) | PNY Elite Perfomance 512GB SDXC card
Network:
(500Mbps↑/500Mbps↓)        ┌─────────────── Office/Rack ──────────────────────────────────────────────────────────────────────────┐
Google Fiber Webpass ────── UniFi Security Gateway ─── UniFi Switch Flex XG ═╦╤╦═ Veda (general traffic)
╔════════════════════════════════════════════════════════════════════════════╝│╚═ Narrative (Asus 2.5G USB NIC)
║ ┌────── Closet ──────┐   ┌─────────────── Bedroom ─────────────────┐        └── UniFi Switch 8-60W ─┬─ Veda (management)
╚═ UniFi Switch Flex XG ═╤═ UniFi Switch Flex XG ═══╦═ Byarlant                                       └─ UniFi CloudKey Gen2 (PoE)
   (PoE)                 │                          ╚═ Jesta Cannon*
                         │ ┌─────────────── Media Center ──────────────────────────────────────────┐
Notes:                   └─ UniFi Switch 8 ─────────┬─ UniFi Access Point nanoHD (PoE)
═══ is Multi-Gigabit                                ├─ Sony Playstation 4
─── is Gigabit                                      ├─ Pioneer VSX-S520
* = cable passed to Bedroom from Media Center       ├─ Narrative** (Belkin USB-PD Ethernet Dongle)
** = cable passed from Media Center to Bedroom      └─ Work Laptop** (Startech USB-PD Dock)
Retired/Other:
Laptop (Rozen-Zulu): Sony VAIO VPCF13WFX | Core i7-740QM | 8GB Patriot DDR3 | GT 425M | Kingston 120GB SSD | Blu-ray Drive | Intel 7260 Wifi (lived a good life, retired with honor)
Testbed/Old Desktop (Kshatriya): Xeon X5470 @ 4.0GHz | ZALMAN CNPS9500 | Gigabyte EP45-UD3L | 8GB Nanya DDR2 400MHz | XFX HD6870 DD | OCZ Vertex 3 Max-IOPS 120GB | Corsair CX430M (?) | HooToo USB 3.0 PCIe Card | NZXT H230 Case (mostly intact, but some parts have been scavenged)
Do I have any other options for smartifying my system without resorting to making my own firehazard smart controllers that connect to bluetooth instead?
Look into home assistant, and zigbee or Z-wave.
Home assistant is a nice little piece of software that will control everything and tie all the different ecosystems together.  For instance, I have almost no HomeKit compatible devices, but with home assistant I can present them all to my iPhone and control them via HomeKit.
Rig: i7 10700k @ 5.1Ghz, 4.8 Ring - - Z490 Vision G - - EVGA RTX 2080 XC Ultra @ 2025Mhz - - 4x8GB Vengeance Pro 3000Mhz 15-17-17-34 @ 3500MHz 16-19-19-38 - - Samsung 950 Pro 512 NVMe Boot + Main Programs - - Samsung 830 Pro 256 RAID 0 Lightroom + Photo work - - WD Blue 1 TB SSD for Games - - Corsair RM850x - - Sound BlasterX EA-5 - - EK Supremacy Evo - - XT45 X-Flow 420 + UT60 280 rads - - EK Full Cover GPU Block - - EK XRES RGB PWM - - Fractal Define S2 - - Acer Predator X34 -- Logitech G502 - - Logitech G710+ - - Logitech Z5500 - - LTT Deskpad
Headphones/amp/dac: Schiit Lyr 3 - - Fostex TR-X00 - - Sennheiser HD 6xx
Homelab/ Media Server: Proxmox VE host - - 512 NVMe Samsung 980 for VM's/Proxmox boot - - Xeon e5 2660 V4- - Supermicro X10SRF-i - - 128 GB ECC 2133 - - 10x4 TB WD Red RAID Z2 - - Corsair 750D - - Corsair RM650i - - Dell H310 6Gbps SAS HBA - - Intel RES2SC240 SAS Expander - - TreuNAS + many other VM’s
iPhone 14 Pro - 2018 MacBook Air
The reason why they are only 2.4 Ghz is because as you go up in frequency you get less range and penetration power. 2.4 Ghz likely would be able to cover most of a parsons house, 5Ghz may cover the house depending on on big. Also a lot of IoT devices dont require a lot of bandwidth so there really isn't any point to them having 5Ghz radios. I recall a proposed WiFi standard using the 800 or 900 Mhz band for this purpose, but I dont think it was ever ratified.
For good reason I suspect.  Would be great if you live in a mansion but imagine people trying to use it in dense apartment complexes where the range would mean hundreds of a different networks all talking over each other.  Also good luck if the devices you use have poor security, someone miles away could be fiddling with your devices.
Router:  Intel Celeron N5105 (pfSense) WiFi: Zyxel NWA210AX (1.44Gbit peak at 160Mhz 2x2 MIMO, ~900Mbit at 80Mhz)
Switches: Netgear MS510TXUP, Netgear MS510TXPP, Netgear GS110EMX
ISPs: Zen Full Fibre 900 (~915Mbit down, 115Mbit up) + Three 5G (~900Mbit average down)
Folding@home Live Stats  Folding@home Recent WUs
I was wrong. It was a published standard. https://en.wikipedia.org/wiki/IEEE_802.11ah Just no one decided to use it.
Is there any way at all to turn my wifi into 2.5 ghz or am I shit out of luck?
I think WiFi 5 and newer routers are required to be simultaneous multi band, based on the standard. WiFi 4 was the only standard where it might be one or the other.
Are both of your bands using the same SSID? I've seen more routers (esp ISP provided ones) merge both and let the client and router sort out which band to use.
Network:
Retired/Other:
I don't know what any of that means how do I find out?
Make and model of router.
