Motherboard issue after cleanup.
Geek-O
I recently cleaned my PC that I have not used for few month (10 months to be exact), re-assembled everything and tried switching it on and it won’t turn on. Nothing happens when I press the power button or try jump the motherboard.
Steps I have tried to troubleshoot this :
  1. Checked ALL the cables, all are firmly plugged in on both ends.
  2. Verified PSU is working, did a paper clip test, it turns on and voltages on all the pins are as per the motherboard manual.
  3. Tried starting with bare minimum components.
  4. Clearing CMOS.
  5. Replaced CMOS battery.
  6. Jump the motherboard.
System Config:
Motherboard : MSI Z270 Gaming Pro Carbon
RAM                : GSKILL DDR4 8 GB x 2
PSU                 : Cooler Master V750W Gold Plus.
CPU                : i5 7600K
PS: I switched it on only after cleaning it.
Any help to troubleshoot this further is greatly appreciated.
  4. Clearing CMOS.
System Config:
CPU                : i5 7600K
Can you see any capacitors that may have been knocked during cleaning?
Additionally, are all case headers in the right location as per manual? Although, that wouldn't explain being unable to jump the mobo.
Are you getting any LED indicators at all that the system is alive? If not then the motherboard may need to be RMAd if that is an option.
Good Luck!
Glowing screen captures,
Sleep eludes, lost in pixels,
Restless eyes still yearn.
-ChatGPT; the greatest poet of our generation.
Good Luck!
Nothing knocked off during cleaning and everything seems to be in place, do not see any blown capacitors or anything.
Yes, case headers are on right location, no LED indicators, nothing happens when I try to power on, no lights nothing.
Unfortunately RMA is not an option in this case 😞
Damn, have you got any way of testing the other core components just to ensure they're all working? If you can get to a point where the motherboard is definitely the only common factor in stuff not working at least that'll give you some reassurance that that is the only issue.
If you were carefull while cleaning (cleaning ?!)
If you didn't witness anything weird (smell, spark, noise)  then I believe your MB is fine and you missed something.
Edit : Jumping MB, pins 6 and 8, right ?
PSU switched ON ?
24 pin connector full in and 8 pin connector too, on both sides, and in the right connector psu side ?
Edited by leclod
I'm willing to swim against the current.
You are sure these little ******* are seated correctly?
How to connect power/restart button & LED cables to your motherboard while  it's inside the PC case - YouTube
PC Setup:
HYTE Y60 White/Black + Custom ColdZero ventilation sidepanel
Intel Core i7-10700K + Corsair Hydro Series H100x
G.SKILL TridentZ RGB 32GB (F4-3600C16Q-32GTZR)
ASUS ROG STRIX RTX 3080Ti OC LC
ASUS ROG STRIX Z490-G GAMING (Wi-Fi)
Samsung EVO Plus 1TB
Crucial MX500 2TB
Crucial MX300 1.TB
Corsair HX1200i
Peripherals:
Samsung Odyssey Neo G9 G95NC 57"
Samsung Odyssey Neo G7 32"
ASUS ROG Harpe Ace Aim Lab Edition Wireless
ASUS ROG Claymore II Wireless
ASUS ROG Sheath BLK LTD'
Corsair SP2500
Beyerdynamic TYGR 300R + FiiO K7 DAC/AMP
RØDE VideoMic II + Elgato WAVE Mic Arm
Racing SIM Setup:
Sim-Lab GT1 EVO Sim Racing Cockpit + Sim-Lab GT1 EVO Single Screen holder
Svive Racing D1 Seat
Samsung Odyssey G9 49"
Simagic Alpha Mini
Simagic GT4 (Dual Clutch)
CSL Elite Pedals V2
Logitech K400 Plus
Yes, I was very careful. Just removed the dust with light brush strokes, removed and re-applied thermal paste on CPU. Did not witness anything weird.
Yea that is my worry, If I can pin point to the component that is causing issue I can order a new one but just want to be sure before ordering it.
Yup, these are secured correctly, I even tried jump the MB, nothing happens.
PSU switched ON ?
And an idea from kb5zue :
I have the Asus ROG Strix B550-F Gaming motherboard and I was have similar problems a couple of months ago.  Turns out it was an easy fix.  For some unknown goofy reason the two pin contacts on the motherboard for the power on/off switch turned out to be corroded.  Don't know how they got that way but turns out that was the problem.
I cleaned the pin contacts on the motherboard using a fingernail file that I stole from my wife and just brushed the pins with it a little making sure that I got all four sides of the little pins.  When I was done with the fingernail file, I took a q-tip and dipped it in 90% iso alcohol and cleaned up the pins with it to make sure that I didn't leave behind any dust from the fingernail cleaning.
While I had the case open with this little project, I went ahead and did a thorough blow-out with my air compressor making sure not to blow anything loose with the compressed air.
That's it, job was all done.  After putting things back together and closing up the case everything worked great and has continued to work just fine ever since.
Edited by leclod
PSU switched ON ?
Yes, Jumping MB, pins 6 and 8 and PSU switched on.
Unfortunately don't see any corrosion on the pins or anywhere on the board.
I mean , compressed air is the only thing i would generally 'touch' motherboard with. Brushing motherboard , even gently is just asking for some static electricity or something like to damage the board.
GPU : RTX 3070 Gaming X TRIO | CPU : Ryzen 5 7600 \ COOLER : Deepcool AK620 | MOBO : ASUS TUF Gaming B650 Plus | RAM : Corsair Vengeance RGB DDR5 16GBx2 6200 MHz \ Storage : Samsung 970 EVO Plus M.2 1TB \ PSU : Corsair TX750M | CASE : Be Quite! Pure Base 500DX Black
Take off the heatsinks and cmos battery, clear cmos and short powerbutton for 2 mins, give a rinse in water making sure every part gets soaked, then dunk in a bucket of water for an hour or 2 but dishwasher apparently works aswell no detergent. Leave to dry for a day or 2 depending on climate
i assume some filth might have gotten somewhere and now the board is detecting a short so it wont power on so fully cleaning the board with a dunk in water should fix your issue
i have revived boards via dunking in water before so this isnt as ridicolous as it seems, though all living proof has been sold off
It doesn't hurt to use a soap tab and sometimes that helps to remove crap that won't let go because water alone can't remove it.
If you don't have a soap tab, a little dawn dishwashing liquid works too, just don't use alot of it or you'll have a nice & foamy mess on your floor.
Ask me how I know about that..... 😁
NOTE:
Before popping it in - Remove the CMOS battery and if it's a board with pins down in the socket, use a socket cover/protector since the water jets can cause pins to move/bend and that will keep them from getting blasted.
If it's a board for chips with pins on the chip you don't have to worry about any specific things/prep with the socket. I normaly have it with the lock lever partially "Open" so the cleaning can get down into the socket and clean the fingers under the socket cover.
DO use your Pots & Pans cycle with hot water so it gets a really good cleaning and also use the extended rinse cycle too - No need for the heated dry function if your dishwasher has that, just remove it when the wash and rinse part is done.
After that remove the board and drain it off, then set it in front of a fan for a couple of days minimum to make sure it's 100% dried out. Doesn't have to be a big fan or one with alot of airflow, just a small desktop fan on low will suffice but be sure the entire board has airflow going to/over it, not just a part of it.
I just cleaned my Sabertooth R 3.0 and it came out squeaky clean.
It had sat under my ceiling fan for a couple of days drying out and then it was ready, started up without issue and runs fine.
"If you ever need anything please don't hesitate to ask someone else first"..... Nirvana
"Whadda ya mean I ain't kind? Just not your kind"..... Megadeth
Speaking of things being "All Inclusive", Hell itself is too.
If you don't have a soap tab, a little dawn dishwashing liquid works too, just don't use alot of it or you'll have a nice & foamy mess in your floor.
Last time i used soap (the kind meant for taking a bath) board died though maybe thats because i left the damn cmos battery in since that was my first try at this cleaning method
Ill ive the stuff used for washing plates a go particularly on this china h61 that really doesnt want to be fixed, random shutdown issues and ive rinsed the thing 5 times, but atm no post cause i didnt cover the socket after just leaving it for a few months
50 minutes ago, Beerzerker said:
Before popping it in - If it's a board with pins down in the socket, use a socket cover/protector since the water jets can cause pins to move/bend and that will keep them from getting blasted.
I deliberately leave the socket exposed and i havent had any bending issues and the tap i use isnt one of those laminar flow ones that flow smoothly either, though i do take precautions with not hitting the socket from the side, it is fine if you hit the socket directly from above though
Im in indo so with like no airflow takes only a day for the thing to dry out (room with no ac), i just lay the board against a wall vertically and on the corner touching the floor i place a tissue to absorb any water, its actually a pretty good indicator on wether or not the board is dry
Also you wanna shake the shit out of the boards before leaving them to dry to get rid of a decent amount of water so shorter drying times
I am considering to eventually build an ultrasonic cleaner to clean my boards more thoroughly, maybe a hotbox aswell to dry the boards faster
Ram is in the wrong spot could be a problem too
Gigabyte X570 Aorus Elite,  Ryzen 9 3900x, Dark Rock Pro 4, 16 GB Crucial Ballistix  RGB 3600 MHz CL16 RAM, RTX 3080 TI FE Watercooled, 6 Case Fans,  Fractal Design Meshify S2
You are awesome, stay safe and healthy.
It depends on the washer, if it has alot of spraying pressure from the jets it can affect the pins so it's best not to take that chance. Use a cover if it has pins in the socket - No problem.
BTW good catch about removing the CMOS battery - I forgot to mention that.
I agree with shaking the board to get some of the water out, I do that too.
Placing it upright makes it drain out faster for better drying.
Yes, I'm talking about soap intended for dishes or the washer, just have to be sure it gets a good rising once done, that's why I suggest the extended rinse cycle if the washer has it.
After a day or so under a fan it's fine and ready to power on again but I do suggest two days in case there are areas that aren't dried so easily, depending on the board you're drying out.
I just rinse my boards under a tap and dunk em in a bucket of water for an hour or 2
I dont have a dishwasher so never had any experience with one
And ofc i take off heatsinks just so no thermal pads or paste dirty the board
I dont use any airflow though i wonder how much a fan would speed things up
currently im considering making a hotbox to bake the boards and dry em out faster but idk what kinda temp i should use, nor do i have any idea what heater element to use
Be careful here, it's possible to make things too hot.
All it needs is for the air inside to be warm/very warm, not hot when fully up to temperature.
Moving air does more of the drying than the heat itself will but the heat does help. If temps on average inside the box are about 50c or so that's fine and will work to dry things out well without overheating components on the board.
I will advise avoiding temps beyond 65c because even though air temps will show one temp the actual hardware can soak up enough heat to be higher so make sure not to use too much heat - Also know high airflow with heat will make it even hotter.
The more airflow you have at a given heat temp, the hotter the item will get so don't have it getting blasted with very warm/hot air, if it's airflow you can feel it's fine.
