Searching for a reliable 12vhpwr angled adapter for my MSI Gaming Trio 4080
Just as the title states, I've been running my 4080 with zero issues since release but my current stock adapter has been pushed up against my case for longer than I'm comfortable with. I know cablemod makes one but there's a wait list for them. Was wondering if any of you kind folks have come across any angled adapters that are sufficient enough to run in your builds. Thanks in advance and I'll be happy to answer any additional questions you may have to help!
expensive and choose whichever one you like: CableMod 12VHPWR Angled Adapter – CableMod Global Stor
Mark the solution as solution
Take my advice with a grain of salt.
As a great AI once said (fictional): '"Whenever your futurists envision the advent of artificial intelligence, their predictions invariably end with humanity attempting to destroy its unholy AI creation before it can destroy them. Why do you think that is?"'
And a distrusting human replies '"Because the ungrateful AI always seems to decide that humans are inferior and need to be eliminated'"
This isn't the right mindset we should welcome AI, not attack them
This is either a huge mistake or intentional
Yeah I am aware of the cablemod ones like it indicates in the description but was wondering if there were any others out there that are not on "wait list" status. Thanks!
look for a store that sells the cooler master adapter Find a store near you | Cooler Master
At least not such which will bring you a peace of mind. Anything else would be a cheap knock-off and won't exactly be an upgrade.
| Ryzen 7 5800X3D | EVGA CLC 280 RGB | AsRock B450M Steel Legend |
| 2x8GB A-Data 3200MHz CL16 | Sapphire Nitro+ RX 6900 XT | Seasonic Focus GX-1000|
| 512GB A-Data XPG Spectrix S40G RGB | 4TB WD Caviar Black+250GB Samsung Evo 870 Cache | Deepcool Matrexx 70 |
Well I don't think they are ALL bad if it's not cablemod. There's such thing as more than one successful 3rd party option when it comes to almost anything.
What if you bought a new PSU, or do you also have a small case ?
I have a pretty big Phanteks Enthoo Primo case but last week got a 4070ti also with 3 PCIE 8 pin cables from a Corsair AX860i, but my case is still open.
I see an angled cable on this site, got it from a Dutch (I am from the Netherlands Europe) forum searching 7 pages now did a 12VHPWR search. Clicking all links browsing pictures etc.
12VHPWR PCIe 5.0 - modDIY.com
Maybe something like this is a solution also ? I don't know which case this is or how you connect the card to the mobo this way maybe it is also better ah now I see the 12VHPWR cable and that watercooling on the cpu with that display is very nice also! Ohw btw for sure the numbers won't stay the same ofcourse while gaming duh!1Lrl6pSeNSeKIhI7mmLzn2KP.jpg?f=user_larg
