Help with Gigabyte Aorus RTX 2060 Super thermal pads
Bought in 2019 I finally opened it up today because of 110 degree Celsius temps while gaming. I changed the thermal paste but didn't know anything about thermal pads so I left them as they were but they didn't look in good condition. I wanna change them but what size and mm will be required is my confusion if anyone can help me I would really appreciate. Also the temps have gone down by a little after paste change from 110 C under load to 80-90 under load. How much of a difference will the pads bring? and please help me about the mm and stuff for vram. THanks in advance
20 minutes ago, Shimejii said:
If you didnt destroy them youll be fine. If you butchered them then you have to look up your specific model on a teardown site.
Well I didn't destroy them but it was my first time opening a graphic card. So couple of them tore off while separating the heat sink from the processor chip. But I did put them back together in place.
