Flat Ethernet cable
Raistlin
Looking at buying my network setup and saw that there is a flat Ethernet cable. This would look a lot better when running throughout my condo. I saw that it's unshielded but everything I read says should be fine, what did everyone here think?
Wiring for Ethernet is almost always unshielded. (UTP: Unshielded Twisted Pair.) Shielded Ethernet cabling exists, but it's not necessary the vast majority of the time.
For the lengths you're likely to run in a residential setting, the flat cables should be fine. I prefer running proper round cables whenever possible, though.
Dell owns my soul.
Its fine, but I like ultra thin /slim cables better, you can get those in cat6:
Edit: CAT6 UTP***
CPU: Ryzen 5800X3D | Motherboard: Gigabyte B550 Elite V2 | RAM: G.Skill Aegis 2x16gb 3200 | PSU: EVGA SuperNova 750 G3 | Mon: LG 27GL850-B , Samsung C27HG70 |
GPU: Red Devil RX 7900XT |
Sound: Odac + Fiio E09K | Case: Fractal Design R6 TG Blackout |Storage: MP510 960gb and 860 Evo 500gb | Cooling: CPU: Noctua NH-D15 with one fan
FS in Denmark/EU - expand to see:
EVGA GTX 1080ti SC black edition with NZXT G12 bracket (white) + Noctua NF-9A Chomax. AIO: Kraken X53 with 2x NF-S12A (for silence) - Є200
Asus Maximus XI Hero Z390 - Є100
Intel 9700K - Є100
Shipping is paid by customer. All parts is working without any issues. CPU able to OC to 5.3ghz. Optimal clock for all cores 5ghz ~1.3v on load
PM if interested and want pics of the parts. Shipping only to EU member countries + Scandinavia.
check out the Ugreen cables on Aliexpress, mine works fine (they have a slim one)
Shielded cat5/cat6 is a pain in the ass. Every once in awhile I get some wingnut who wants it run in their biz because they think their coffee maker might produce too much EMF.
I mean, its structurally impossible to hurt, but like working with frikken hemp rope in the network closet.
Edit: CAT6 UTP***
TIL slim non-flat cables are a thing.
Visual preferences aside, people should know that with slim cables:
  • Size difference is about 5.8 versus 3.8 mm in diameter
  • The wires inside the cables are thinner (30 versus 24 AWG, larger number is smaller)
  • As a result of the physical wire differences, it doesnt meet standard ANSI-defined specs for cat 6 including...
  • Power over ethernet is more limited (30W)
  • AND max distance is more limited than the 100m standard
I have used flat ethernet cables as well, and with the one I bought and cut open the internal wires seemed to be the same gauge as a normal round cable, but I also didn't take an exact measurement.
It's all about visual and physical preferences for however people use the cable as well as risk tolerance for a cable not confirming to existing standards.
Using a non round standard sized cable means it is less likely that the wires inside will be the same size, unless you trust who makes/sells the cable.
