Help with my first PC build
Go to solution Solved by spaghet rat,
ah ok
PCPartPicker Part List: https://pcpartpicker.com/list/QpBJcb
CPU: Intel Core i5-13500 2.5 GHz 14-Core Processor  ($249.98 @ Newegg)
Motherboard: MSI MAG B760 TOMAHAWK WIFI ATX LGA1700 Motherboard  ($219.99 @ Amazon)
Memory: Kingston FURY Beast 16 GB (2 x 8 GB) DDR5-5200 CL40 Memory  ($76.34 @ Amazon)
Storage: Kingston NV2 1 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  ($49.99 @ Amazon)
Case: NZXT H5 Flow ATX Mid Tower Case  ($94.99 @ Amazon)
Power Supply: Corsair RM750e 750 W 80+ Gold Certified Fully Modular ATX Power Supply  ($99.99 @ Best Buy)
Total: $791.28
Generated by PCPartPicker 2023-03-31 09:38 EDT-0400
Budget (including currency): 700-800 USD
Country: USA
Games, programs or workloads that it will be used for: Valorant, GTA V, and some light video editing and maybe streaming in the future
Other details (existing parts lists, whether any peripherals are needed, what you're upgrading from, when you're going to buy, what resolution and refresh rate you want to play at, etc): I am confused between i7-12700K, i5-13600K or Ryzen 7600X. For now i will be using integrated gpu and will add a dedicated gpu once the 4060 is released(gpu budget is excluded). Also it would be nice to have a future proof system if i need to upgrade sometime in 2 years
Country: USA
Other details (existing parts lists, whether any peripherals are needed, what you're upgrading from, when you're going to buy, what resolution and refresh rate you want to play at, etc): I am confused between i7-12700K, i5-13600K or Ryzen 7600X. For now i will be using integrated gpu and will add a dedicated gpu once the 4060 is released. Also it would be nice to have a future proof system if i need to upgrade sometime in 2 years
the 40 series mid range cards aren't gonna be that good. Just wait until they release and get a used 1080 ti or a 6700 xt
Mark the solution as solution
Take my advice with a grain of salt.
As a great AI once said (fictional): '"Whenever your futurists envision the advent of artificial intelligence, their predictions invariably end with humanity attempting to destroy its unholy AI creation before it can destroy them. Why do you think that is?"'
And a distrusting human replies '"Because the ungrateful AI always seems to decide that humans are inferior and need to be eliminated'"
This isn't the right mindset we should welcome AI, not attack them
This is either a huge mistake or intentional
Country: USA
if your willing to spend a bit more this is a great build https://pcpartpicker.com/list/gxXpC6
but if you wanna stick to your budget then check this one out https://pcpartpicker.com/list/nxXpC6
This is the first time i am building so i wanna stick to new parts, with good warranty and reliability. Thanks for the help
oh ye i mean for later on you could buy a new 6700 xt or 6800. Also maybe nvidia cards if they come down in price (like the 30 series)
Is the 7600 better than 12700K?
And in the second build, instead of B660M, the Z690M i selected is better, right?
ye but the mobo and ram are much more expensive
what makes you believe that 40 series mid range cards are going to be bad?
Get that goddamned number out of my head.
Its still up in the air on whether 4060 or 7700XT would be a good performance per dollar value, and the release date is still up in the air. Id rather save up at 1300$ range and then build one or fully wait till the 4060 and 7700XT numbers are out. We dont even know 4070 figures.
Press quote to get a response from someone! | Check people's edited posts! | Be specific! | Trans Rights
Self Introduction and Current Rig
Hi, have you seen Hoshino Ai recently? Shes not missing, i just thought you should search her on the Internet.
30 minutes ago, filpo said:
all these are leaks/rumors sorta things.and if the 4060 is a bad option i will than take 3060ti or 3070, but for now the main confusion is 7600x or 13600k
radeon has actually gotten really good in the past few years, i would recommend getting a 6800xt. heres the setup i am planning to build myself, and i think it would work for you https://pcpartpicker.com/user/seomen/saved/7VNckL
you dont need an aio for anything but i9 cpus or heavy oc jobs just get an nh-d15 or peerless assassin
MARK THE SOLUTION AS SOLUTION
i am 14 so i may be wrong sometimes
@Bob__ is a w
oh wait just saw your budget
@Bob__ is a w
are you planning on overclocking? because if not then just get a i5-13500 and b760 mobo
@Bob__ is a w
honestly, for the money, currently its better to go with something like the 13600k but its pretty limited by ddr4 memory so maybe the 12700k is a better option
PCPartPicker Part List: https://pcpartpicker.com/list/2XHKv3
Power Supply: Corsair RM750x (2021) 750 W 80+ Gold Certified Fully Modular ATX Power Supply  ($139.99 @ Corsair)
Total: $831.28
you can use the stock cooler and iGPU for now until you get more money
@Bob__ is a w
Total: $831.28
go for a cheaper power supply and spend that money on the 970 evo plus (for the dram cache)
i thought cache isnt as important now? also the powersupply is in case op wants to get a beefy gpu later
@Bob__ is a w
The, Corsair RM750e 750 W 80+ Gold Certified Fully Modular ATX Power Supply, would save $40.
ah ok
Total: $791.28
@Bob__ is a w
i wont be overclocking but 13600k for the higher clock speed
Okay so thank you everyone for helping!! I think i am gonna go with 12700K (to save a bit) and pair it with ddr5 and as for the gpu, if 4060 is good, i will go with it or 6800xt looks great.
5 hours ago, McrP87 said:
ah ok
Total: $791.28
Just changing the CPU to 12700K
8 hours ago, filpo said:
yep, these are all rumours. They might be wrong, and by the improvement with the 4090, 4080 and 4070 ti to there counter parts I feel these will be good cards. Just priced badly.
