I have 3 ancient laptops stripped of removable parts. What should I do with them?
Go to solution Solved by Vishera,
1 hour ago, Needfuldoer said:
Decade-old laptops without issues are a dime a dozen.
My 2013 Fujitsu Lifebook AH532 is in perfect condition, it's my daily driver in addition to my desktop.
In the past few weeks i played Skyrim and Tokyo Xanadu on it having a blast.
I have never had a Laptop, desktop or other expensive electronics die on me.
My 12 years old desktop from 2011 is still working, my LG Optimus L5 is still working, just sold my 2008 Lenovo N500
1 hour ago, DefinitelyRus said:
Are these still worth repurposing? If so, how should I go about it?
Only the Thinkpad.
I have a Samsung Series 5 Ultrabook from 2012 that...
- Has no HDD. Repurposed then sold.
- ... because it has broken SATA ribbon connector which I somehow accidentally cut with scissors, don't ask how; I don't know either.
- Malfunctioning keyboard
- Damaged 30-pin ribbon connector, which prevents the laptop from powering on.
+ RAM still in there because it's soldered.
+ Otherwise works perfectly fine!
+ Wrapped in cling wrap so insects won't invade it anymore.
I also have an old Acer Aspire from around 2009 that...
- Has no HDD. Repurposed and sold.
- So slow that I'd be surprised if Linux Mint Xfce runs on it.
- Has yellowed plastic!
- And yellowed display!
- Has its battery missing.
+ RAM still in there because quite frankly I don't know who'd want it.
+ Otherwise works "perfectly" fine!
+ Also wrapped in cling wrap for the same reason.
And a Lenovo Thinkpad from around 2011 that...
- Is 32-bit so I can't use it for certain programs.
- Does not pass POST 70% of the time because of a malfunctioning CPU fan.
- I think has a virus in it somewhere 😛
- Is not wrapped in cling wrap :((
+Still has HDD and RAM still in it.
+Works perfectly fine if it's in the mood.
+ I like the mouse nub thing
"USB 3.2 Gen 2x2"
throw them all away.. try going the extra mile and dispose of them in ancivilised manner.
they are not worth investing anything into. I get the nostalgia though. I too have sth like 4 laptops I've outgrown and are now just sitting in my storage.. don't have the heart to throw them out.
They're great if you have a door you need to keep held open, or a stack of papers you don't want to blow away.
Decade-old laptops without issues are a dime a dozen. Recycle those since they're all problematic, and it's not worth spending money on fixing them.
Dell owns my soul.
ewaste
System : AMD R9 5900X / X570 AORUS PRO/ 2x16GB Corsair Vengeance 3600CL18 ASUS TUF Gaming AMD Radeon RX 7900 XTX OC Edition GPU/ Phanteks P600S case /  Eisbaer 280mm AIO (with 2xArctic P14 fans) 0.5TB Sabrent Rocket + 2TB WD SN850 NVme Gen4 + 4TB Toshiba X300 HDD drives/ Corsair RM850x PSU/ 34" 120Hz 3440x1440p Alienware AW3420DW monitor / Logitech G915TKL keyboard (wireless) / Logitech G PRO X Superlight mouse
Is this method sufficient for this task?
"USB 3.2 Gen 2x2"
try and sell on ebay? saves them bevcoming ewaste
verey yesz
Only the Thinkpad.
A PC Enthusiast since 2011
AMD Ryzen 7 5700X@4.65GHz | GIGABYTE GTX 1660 GAMING OC @ Core 2085MHz Memory 5000MHz
Cinebench R23: 15669cb | Unigine Superposition 1080p Extreme: 3566
Affirmative, perfectly within reason. I see you're of the civilised sort as well, sire.
Proceed as you will. I shan't stand in your way.
