Best way to connect 6x screens to one PC?
Internet Swag
Hi guys, so I am trying to connect 6 screens to one PC, motherboard is gigabyte ga z97 d3h
They would not be split screens but rather individual outputs. So a hdmi splitter won't work.
Can I use or install two graphics cards in this mobo and use it like that ?
Ryzen 7600X | MSI Trio X 3080 | 3440x1440p asus vg34vql1b | Antec HCG 850 | 1TB WD Blue SSD | 500GB Aorus Elite | Asus B650 Strix A
Depends on your cpu and gpu already installed. If you have an igpu and a gpu that supports 4 displays you could run 2 off of the igpu plugged into mobo and 4 off the gpu. You could also do 2 gpus but you may run into some weird stuff with that if you get a second gpu that uses a different driver.
Edit: I came across another topic when confirming my thoughts that may be useful to read through for you.
Edited by TylerD321
Added link
My PC Specs: (expand to view)
Main Gaming Machine
CPU: Intel Core i7-10700K - OC to 5 GHz All Cores
CPU Cooler: Corsair iCUE H115i RGB Pro XT (Front Mounted AIO)
Motherboard: Asus TUF GAMING Z490-PLUS (WI-FI)
Memory: Corsair Vengeance LPX 32 GB (2 x 16 GB) DDR4-3600
Storage: Intel 665p 1 TB M.2-2280 NVME SSD (x2)
Video Card: Zotac RTX 3070 8 GB GAMING Twin Edge OC
Power Supply: Corsair RM850 850W
Case: Corsair 4000D Airflow
Case Fan 120mm: Noctua F12 PWM 54.97 CFM 120 mm (x1)
Case Fan 140mm: Noctua A14 PWM 82.5 CFM 140 mm (x4)
Monitor Main: Asus VG278QR 27.0" 1920x1080 165 Hz
Monitor Vertical: Asus VA27EHE 27.0" 1920x1080 75 Hz
