i5 11400f and rtx 3080 OR i7 11700f and rtx 3070
I m currently using an i5 11400f cpu and rtx 2080 super. So what should i upgrade. i have 2 options currently:- 1st-Upgrade to i7 11700f and get a rtx 3070. 2nd- only get a rtx 3080. My budget is a little tight currently i can afford only one of the above two options. please someone clarify what should i do.
I'd pick the 3080 and keep the i5.
01001100 01101001 01101110 01110101 01110011 00100000 01010100 01100101 01100011 01101000 00100000 01010100 01101001 01110000 01110011 00100000 01100110 01101111 01110010 01110101 01101101 00100000 01000110 01010100 01010111 00100001
MOBO
ASUS ROG STRIX Z490-G GAMING Wi-Fi
CPU
Intel Core i7-10700K + Corsair H100x
GPU
ASUS ROG STRIX RTX 3080 Ti OC LC
RAM
G.SKILL TridentZ RGB 32GB (F4-3600C16Q-32GTZR)
SSDs
2x Samsung EVO Plus 1TB – Crucial MX500 2TB – Crucial MX300 1.05TB
PSU
Corsair HXi Series HX1200i 1200 Watt 80 Plus PLATINUM
CASE
HYTE Y60 (White/Black) + 2x NOCTUA NF-A14 PWM chromax.black + 3x Corsair LL120 RGB
MONITORs
Samsung Odyssey CRG9 – Samsung Odyssey G9 – Samsung Odyssey G7 Neo
M/KB
Corsair K70 RGMK.2 CHERRY MX Brown – Corsair Ironclaw RGB + Corsair MM300 PRO Extended
AUDIO
FX-Audio DAC-X6 + beyerdynamic TYGR 300 R + Corsair SP-2500 – Steelseries Arctis Pro + GameDAC
3080 all the way. 6 cores is still enough for most gaming tasks, so the extra 2 cores of the 11700F won't be doing a whole lot. Plus given the pricing of 11th gen CPUs on the used market (at least from what I've seen) it's likely the cheaper option.
